davesec Posted February 14, 2013 Posted February 14, 2013 hi, i have a bunch of objects on a particular layer, and they're all different colors and linetypes and lineweights, and i want them to all take on the color/linetype/lineweight that i chose for that layer.. how do i do this? thanks! Quote
rkent Posted February 14, 2013 Posted February 14, 2013 Lock all layers except that layer, select all entities, open properties, change to bylayer for those catagories. You can also use SETBYLAYER command, not sure if it is in 2009 however, too lazy to check. You can also do this at the command line with Change command, Properties option, follow the prompts. Quote
