Hy guys,
I am trying to make a 3d model in autocad. But I have stuck in a problem. When I fillet the surface then I can not trim the extra portion. Please gibe me a suggestion with this. I am attaching the dwg file. I use autocad 2012.
Trim problem.dwg
Please help me in this matter.
Are we talking about trimming back the four curved surfaces where they intersect with an adjacent surface?
What is the object supposed to be? Looks like it would be a real pain to fabricate.
Edited by ReMark
Your fillet do not meet the curved portions of the other walls.
I don't believe fillet is the proper command, try _SURFTRIM.
Yes remark. I want to cut the four curved surfaces where they intersect. But the surface trim option does not work here. When I try that option then the curved surface takes a weird shape, I tried the edge fillet option though. But then I face another problem. I can not get my desired radius. I dont know what should I do.
I explained in post #3, the fillet edges do not meet the curvature, redo without the fillet and use _SURFTRIM, trim one and then the other using one then the other as a cutting edge.
SEANT,
Your drawing file looks the same as the original.
.... I dont know what should I do.
Why are you modeling as surfaces rather than as solid?
If you are going to model as surfaces (maybe you intend to Thicken after trimming?) I would do the four sides as individual surfaces rather than as one extrude.
Another technique might be to model as solid, explode to surfaces and then Thicken the individual sides.
SEANT,
Oops, I renamed the wrong file. See this attached.
ViaSolids.dwg
