Hello, it´s me again...
I have the following situation to resolve:
I am in the process of drawing a corner bench which later on I will produce from solid wood.
The backrests of the bench are simple boards. Now I came to the point where I need to trim these boards to make them form the corners. To be able to gain the right angles and measures I am drawing the hole thing in 3d (and also for presenting it to my customers).
Here is a profile drawing from the bench construction to make it a bit easier to understand:
I extracted two of the intersecting boards from my drawing, as seen in the following drawing:
[ATTACH]40478[/ATTACH]
I made a simple sketch to demonstrate the result I want to achieve.
Pleas let me know wether I have been clear about my request.
Greetings
Len
How are you attempting to do attachments here (Go Advanced)?
I would have swept or extrude the profile of one of the simple backrest boards along a path defining the center line of the entire back of the bench including the angled portion.
@ JD
Oops something went wrong.. I did it the way you propose initially but then had to shut down my computer and copy-pasted the text including the attachments...
I tried if I could still open them. It worked but probably does so only on my computer...?
One bench back rail.
So slicing no dicing.:lol:
Beautiful! I had thought there must be a simple solution to that!
Thank you!
Now I am only wondering whether there will be a difference between the results of this two methods when it comes to extracting values...??
Examine the solutions carefully - there are two different joints - a lap joint in one and a miter joint in the other.
You need to decide.
Doing the sweep method I automatically got the mither joint - the one I wanted. Thanx JD
Here´s the next one ;-)
For the corner peace of the seating surface I´d like to apply the sweeping and slicing. To make it as simple as possible I´d like to use the green extruded part for slicing the swept part of the seating surface (brown). But I don´t know how.... With the SLICE command I can´t choose such an object as the slicing one...
[ATTACH]40487[/ATTACH]
