Can anyone help me with this block.
When I insert it into a drawing I can switch between 2 blocks on the drop down menu.
The only problem is when I change between the 2 the position of the block moves.
They don't appear to have the same base point, even though they are on top of each other within the block and positioned at 0,0,0.
You can notice with the Emergency fitting that the E is way out when switched between the fittings. Even though within the block it is set up right next to it.
Low Energy Downlighter_.dwg
Have you tried editing the block to correct the problem?
Yes I cannot work out why it won't work. As far as I am aware I have done everything as it should be.
I know the block is different, but the problem seems to be the same.
Similar type of problem, although the answer from the last problem doesn't work with this problem.
