Hi guys,
Just trying to create a transition, with the thickness shown, from one sketch to another. Kind of confused, I thought this was a loft operation.
Also should they be in the same sketch?
Okay so I resolved that lol... but now how do I create a plane at a 45 degree angle..
What I'm trying to do is create a handle, initially the first part juts out normally but then the second part of the handle is 45 degrees to the other part...
  • 2 weeks later...
You don't need to create a plane at 45 degrees, use the "yellow" highlighted plane and create a "side view" sketch on that, then extrude.
Hopefully that should help you.
