error: EOF after quote on input
heres my pc specs:
OS: win 7
cad: autocad 2002
Can you please post the code excerpt?
icon1.png Re: Error:EOF after quote on input
Because READ respects certain characters reserved for lisp evaluations. A quote "'" is read as the function QUOTE:
(read "a") returns the symbol A, but
(read "'a") returns (QUOTE A)
It's the same thing that makes READ capable of returning lisp expressions, as in
(read "(cons 2 4)")
where the left parenthesis signals a lisp expression. Whenever READ bumps into a reserved character it expects an expression to follow. You'll have to check the returned character before using READ.
don't know if this will help or not - found it on another forum and thought i would pass it on
i can't spicified which part of the lisp is error
here's the pic
Taking into account what Welldriller posted, you may want to search into your code for line(s) of code containing the string below and post it/them here for someone to have a look at:
(read
PS. Please make sure that Match Case option is uncheked.
Edited by MSasu
addition on Match Case option
As indicated by welldriller's post, the following will cause the error:
_$ (read "'")
; error: EOF after quote on input
Since there are no expressions following the quote symbol.
