i dont understand hot to use entmod to change the value of text
heres what i got so far..
i just wanted to change the number value.
(defun C:ddip (/ ss d dstring)
(setq ss (ssget "_:S" '((0 . "TEXT"))))
(setq d (getint "\nEnter Dip :"))
(setq dstring (strcat (itoa d)"°"))
(entmod (subst dstring))
(princ))
(entmod (subst (cons 1 (strcat (itoa d) "%%C")) (assoc 1 (setq e (entget (ssname ss 0)))) e))
A Vl version also if d is only being used here why make it a number ? I know error trap but you have to have some faith in end users.
(defun c:ddip ( / obj str )
 (setq obj (vlax-ename->vla-object (car (entsel "pick text object"))))
  (if  (or (=  "AcDbText" (vla-get-objectname obj)) (=  "AcDbMText" (vla-get-objectname obj)) )
     (setq str (strcat (getstring "\nEnter dip") "%%c"))
     (vla-put-textstring obj  str)
Edited by BIGAL
Thanks Tharwat changed as you must have typed reply. Its 8:21 pm here what time where you are ?
Had one version in notepad other in Vlide posted wrong one.
Sorry for this late reply. The time was 1:21 pm here so there are five hours deference between our both timing.
No worries Tharwat.
Added the mtext check for simple text edit.
Hi,
Actually there is no need to convert to vla-object to get the job done.
Anyway, if I planned to write it with vlisp then I will go with the following track.
(defun c:ddip (/ obj str)
 (and (setq obj (car (entsel "\nPick text object :")))
      (setq obj (vlax-ename->vla-object obj))
      (wcmatch (vla-get-objectname obj) "AcDb*Text")
      (/= "" (setq str (getstring "\nEnter dip :")))
      (vla-put-textstring obj (strcat str "%%c"))
) (vl-load-com)
Thats clever! :thumbsup:
Just a minor correction - it doesn't look like OP wants the diameter symbol, but the degree slope one:
_$ (vl-list->string '(37 37 99))
"%%c" ; <- labels pipe diameter
_$ (chr 176)
"°" ; <- labels slope in degrees
Thank you. :)
I agree with you, so the OP has two options now ( diameter / degrees [ %%C , %%D ] ). ;)
