the_phil Posted October 7, 2008 Share Posted October 7, 2008 hi, double clicking any sort of text isn't working - don't know exactly how this happened, it was working fine when i first started up this morning - have i messed with a setting somewhere? Quote Link to comment Share on other sites More sharing options...
nocturne00 Posted October 7, 2008 Share Posted October 7, 2008 check your selection settings, Options> Selection> Selection Mode> Check noun/Verb Selection Quote Link to comment Share on other sites More sharing options...
the_phil Posted October 7, 2008 Author Share Posted October 7, 2008 yep did that double click editing setting was on. sussed it out in the end - other commands weren't working properly either, looking through the system variables "SETVAR" discovered that "PICKFIRST" was off. still - don't know how that happened. Quote Link to comment Share on other sites More sharing options...
nocturne00 Posted October 8, 2008 Share Posted October 8, 2008 yep did that double click editing setting was on. sussed it out in the end - other commands weren't working properly either, looking through the system variables "SETVAR" discovered that "PICKFIRST" was off. still - don't know how that happened. that would be the same as the non/verb selection setting under option. this commonly happens when you are using the MVSETUP command, when aligning or rotating viewports, it resets your ONSNAP and PICKFIRST variable (but only until the command is done). If you terminate the command prematurely (ESC), changes done by the MVSETUP command will retain, thus your PICKFIRST variable, ONSNAP settings are screwed up Quote Link to comment Share on other sites More sharing options...
the_phil Posted October 8, 2008 Author Share Posted October 8, 2008 that's it !! i was using mvsetup - i aligned rotating but put the wrong angle in for the rotate and just escaped from the command genius Quote Link to comment Share on other sites More sharing options...
bonehead411 Posted October 8, 2008 Share Posted October 8, 2008 Genius indeed. LT 2005 doesn't have the MVSETUP function, but I'll try and retain this little nugget in case we ever upgrade to full AutoCAD. Quote Link to comment Share on other sites More sharing options...
