ksperopoulos Posted June 13, 2010 Share Posted June 13, 2010 I am trying to incoporate this command (setbylayer) into a lisp routine that I am making to clean up our xrefs. I am trying to adjust the settings to change only the color, select all objects in the drawing, change byblock to bylayer, and to include blocks. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted June 13, 2010 Share Posted June 13, 2010 I am trying to incoporate this command (setbylayer) into a lisp routine that I am making to clean up our xrefs. I am trying to adjust the settings to change only the color, select all objects in the drawing, change byblock to bylayer, and to include blocks. Any help would be appreciated. For starters you could look into SETBYLAYERMODE variable. SETBYLAYERMODE Type: Integer Saved in: Registry Initial value: 127 From the AutoCAD Help Section under system variables. Controls which properties are selected for SETBYLAYER The setting is stored as an integer using the sum of the following values: 0 No properties are selected 1 Color property 2 Linetype property 4 Lineweight property 8 Material property 16 Plot Style property 32 Changes ByBlock to Bylayer 64 Includes blocks when changing ByBlock to ByLayer There is also other information there not shown here. Also look into ssget in the Developer Help Section Creates a selection set from the selected object (ssget [sel-method] [pt1 [pt2]] [pt-list] [filter-list]) Selection sets can contain objects from both paper and model space, but when the selection set is used in an operation, ssget filters out objects from the space not currently in effect. Selection sets returned by ssget contain main entities only (no attributes or polyline vertices). Maybe this thread will give you some idea:http://www.cadtutor.net/forum/showthread.php?t=42062&highlight=SET+BYLAYER+LISP 1 Quote Link to comment Share on other sites More sharing options...
ksperopoulos Posted June 13, 2010 Author Share Posted June 13, 2010 How is this. (FYI - I am a novice at this stuff) (defun c:cleanxref2 () (command "setvar" "cmdecho" 0)(command "setbylayermode" "1") (command "setvar" "cmdecho" 0)(command "setbylayer" "all" "" "y" "y")(princ)) Quote Link to comment Share on other sites More sharing options...
ksperopoulos Posted June 14, 2010 Author Share Posted June 14, 2010 The setbylayer command doesn't seem to get dimensions that have the text set to a different color. Is there a setting in this command that can access all annotation items in a drawings as well as all the other items this command is changing to bylayer? Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted June 14, 2010 Share Posted June 14, 2010 The setbylayer command doesn't seem to get dimensions that have the text set to a different color. Is there a setting in this command that can access all annotation items in a drawings as well as all the other items this command is changing to bylayer? That because its part of a named dimstyle. In that case you would need to get a selection set of all dimensions and change the dimstyle variables of the named dimstyle to bylayer. Seems you will have some addtional coding to do. Dimension Text: DIMCLRT Dimension Lines: DIMCLRD Dimension Ext Lines: DIMCLRE Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted June 14, 2010 Share Posted June 14, 2010 ksperopoulos, Below is a code that I found on Afralisp http://www.afralisp.net/archive/lisp/clay.htm that touches the subject of setting entities color properties to bylayer. There are other areas such as linetype and blocks to give you a better idea on how to proceed. Once you get the idea with this code, The rest should become easier I hope. Afralisp has a great way of explaining things in simple terms to make it easier to learn. For linetypes and blocks you can find coding on Afralisp as well. You can refine them to your need as you see fit. This code deals with setting color on most general entities. I just changed the long name from ColorToLayer.lsp to CTL.lsp. ;CODING BEGINS HERE (defun c:CTL () (setq i 0 n 0) ;clear the loop control variables (prompt "\n Select entities to analyze ") ;prompt the user (setq sel (ssget)) ;get the selection set (setq n (sslength sel)) ;get the number of objects (repeat n ;start the loop (setq entity (ssname sel i)) ;get the entity name (setq name (entget entity)) ;now get the entity list (if (not (assoc 6 name)) ;if not Bylayer (progn ;do the following (setq layer (cdr (assoc 8 name))) ;retrieve the layer name (setq layerinf (tblsearch "LAYER" layer)) ;get the layer data (setq layercol (cdr (assoc 62 layerinf))) ;extract the default layer colour (setq name (append name (list (cons 62 layercol)))) ;construct an append the new list (entmod name) ;update the entity (entupd entity) ;update the screen ) ;progn ) ;if (setq i (1+ i)) ;increment the counter ) ;repeat (princ)) ;defun (princ) ;CODING END HERE Quote Link to comment Share on other sites More sharing options...
ksperopoulos Posted June 15, 2010 Author Share Posted June 15, 2010 Thanks Buzzard! I've got a lot to learn. Quote Link to comment Share on other sites More sharing options...
MadMox45 Posted September 28, 2023 Share Posted September 28, 2023 On 6/13/2010 at 2:43 PM, ksperopoulos said: How is this. (FYI - I am a novice at this stuff) (defun c:cleanxref2 () (command "setvar" "cmdecho" 0)(command "setbylayermode" "1") (command "setvar" "cmdecho" 0)(command "setbylayer" "all" "" "y" "y")(princ)) How would you write this if you wanted to do it on multiple files within the same folder? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 29, 2023 Share Posted September 29, 2023 (edited) You can write a SCRIPT that will open a dwg and run the 2 lines then close and save. A script is like writing down the commands that you manually type but can have lisp. Save script as a .scr file. Not tested. Open dwg1 (command "setbylayermode" "1") (command "setbylayer" "all" "" "y" "y") close y Open dwg2 (command "setbylayermode" "1") (command "setbylayer" "all" "" "y" "y") close y Open dwg3 (command "setbylayermode" "1") (command "setbylayer" "all" "" "y" "y") close y Dont worry about cmdecho as screen will flash anyway. Google Running scripts autocad Edited September 29, 2023 by BIGAL Quote Link to comment Share on other sites More sharing options...
