mikekmx Posted July 31, 2013 Share Posted July 31, 2013 Hi there must be a quick way (/)... or at least a way: like in Excel & Word & many other progs, when in PS i'd like my view to be at 100%....so if i plotted, my (eg) PS titleblock would be the same size on paper as on the monitor. P.S. i fully admit i looked in AutoCAD help for about 30secs, then posted here Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 31, 2013 Share Posted July 31, 2013 ...like in Excel & Word... ... same size on paper as on the monitor. I am curious - I want to know how to have Word print the same size on paper as on the monitor? (I have never ever had the need for this - but as I stated - curious.) I always print paperspace at 100%, but that isn't necessarily the same size it displays on the monitor? Can you attach a sample file here to illustrate your problem? Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 31, 2013 Share Posted July 31, 2013 I don't see the point of printing something at the same size as it is on one's monitor. Please cite three examples. Quote Link to comment Share on other sites More sharing options...
nestly Posted August 1, 2013 Share Posted August 1, 2013 I would say I don't see a need for this either, however to sync the sizes, simply divide the length of a sheet of paper by the length of the "paper" on the monitor (use a ruler) then ZOOM by the dividend while in PaperSpace. ...or buy an Asus monitor with QuickFit grid Quote Link to comment Share on other sites More sharing options...
mikekmx Posted August 1, 2013 Author Share Posted August 1, 2013 sorry, i didn't expalin very well... in PS, what i'd like to do is 'click' and zoom my view to 100% (or 1:1) so it's the same size as it will be on paper. the reason: at pesent i plot to PDF then view 100%, to check things are legible, check the vp scale is suitable etc. Being able to do this in AutoCAD would save some time. i try to set things up so my drawings are best plotted at A1 but are still legible if plotted at A3 size, but what tends to happen is they are too big on A1. i want to be able to check as i go along and with less effort. just bought a new HP 23" monitor, so the Asus is not an option Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 1, 2013 Share Posted August 1, 2013 As far as I know, AutoCAD does not have a way to do that without the calculation that nestly mentioned. For your needs, I would think a close approximation would be good enough. Even with "Lineweights" turned on, what you see on the screen is not going to be exactly as it is going to appear on paper. PDFs viewed at 100% do not even do that. Most of the time they are close but I've seen some major differences between what a PDF shows on the monitor, especially when zoomed in, and what the printed PDF looks like. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 1, 2013 Share Posted August 1, 2013 ...to check things are legible........ but are still legible if .... Text size (printed) should be the same on any size plot. For the geometry it should be obvious of sheet size/view scale that is needed. Quote Link to comment Share on other sites More sharing options...
