ronjonp Posted April 12, 2018 Share Posted April 12, 2018 Sorry mr. ronjonp for wasting your time.Aggression cannot, under any circumstances, solve none problem! You did not waste my time... Quote Link to comment Share on other sites More sharing options...
lido Posted April 12, 2018 Author Share Posted April 12, 2018 Just test only.. [color="green"];At this level we can list out [/color] ([color="blue"]vl-registry-descendents[/color] (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key) "\\Applications\\") ) [color="green"];but why this level doesn't work ???[/color] ([color="blue"]vl-registry-descendents[/color] (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key) "\\Applications\\" "AcEAttEdit" [color="red"]"\\Commands"[/color] ) ) another approach (defun foo (app cmd) (and (setq app (findfile app)) (vl-registry-read (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key) "\\Applications\\" (vl-filename-base app) "\\Commands") (strcase cmd ) ) ) ) _$ (foo "AcEAttEdit.arx" "EATTEDIT") [b][color="blue"]T[/color][/b] Thank you hanhphuc for your replay. Your first snippet returns a list containing the loaded applications. Not at all built-in commands. So, your second snippet return nil for any (?) built-in command. Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted April 12, 2018 Share Posted April 12, 2018 (edited) Thank you hanhphuc for your replay.Your first snippet returns a list containing the loaded applications. Not at all built-in commands. So, your second snippet return nil for any (?) built-in command. yes that's the problem, if we could get the commands descendent list then we could collect all the command, but it failed. That's why I tried another predicate sub (foo app ac cmd) ;edited post#20 but this method is not user friendly unless you know the app & name or (app list by vlookup or assoc) app="AcTable.arx" name="AcadTable" example: (foo "AcTable.arx" "AcadTable" "TINSERT") IMO Roy043 has offered the best solution Edited April 12, 2018 by hanhphuc the best deserves the smiley Quote Link to comment Share on other sites More sharing options...
rlx Posted April 12, 2018 Share Posted April 12, 2018 To my knowledge there is no way to obtain a list of command names via Lisp code. For _eattedit and other commands that require user input something like this should work (on most CAD platforms I believe): (defun CommandAvailable_P (cmd / ret) ) Smart one Roy! Quote Link to comment Share on other sites More sharing options...
ronjonp Posted April 12, 2018 Share Posted April 12, 2018 Smart one Roy! Agreed .. nice job. Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted April 12, 2018 Share Posted April 12, 2018 (edited) i think i missed something , i fixed here (defun appcom ( / key l lst ) ;hanhphuc 13.04.2018 (setq key (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key) "\\Applications\\")) (cdr (acad_strlsort (apply 'append (mapcar ''((app) (vl-registry-descendents (strcat key app "\\Commands") [color="red"]app[/color] ) ) (vl-registry-descendents key ) ) ) ) ) ) 384 arx commands @ ac2007 ("-3DCONFIG" "-AecDwgUnits" "-AecExportToAutoCAD" "-ARCHIVE" "-BEDIT" "-BVHIDE" "-BVSHOW" "-BVSTATE" "-COPYTOLAYER" "-DIMSTYLE" "-DWFADJUST" "-DWFATTACH" "-EATTEXT" "-ETRANSMIT" "-FIELD" "-HYPERLINK" "-IMAGE" "-IMAGEADJUST" "-INTERFERE" "-LAYDEL" "-LAYMCH" "-LAYMRG" "-MTEXT" "-OPENSHEETSET" "-PLOTSTAMP" "-PUBLISH" "-REFEDIT" "-SHADEMODE" "-TABLE" "-UNITS" "-UPDATEFIELD" "-VBALOAD" "-VBARUN" "+DSETTINGS" "+PUBLISH" "3DALIGN" "3DCLIP" "3DCONFIG" "3DCORBIT" "3DDISTANCE" "3DDWF" "3DDWFPUBLISH" "3DFLY" "3DFORBIT" "3DORBIT" "3DORBITCTR" "3DORBITTRANSPARENT" "3DPAN" "3DPANTRANSPARENT" "3DSIN" "3DSWIVEL" "3DSWIVELTRANSPARENT" "3DWALK" "3DZOOM" "3DZOOMTRANSPARENT" "ACAD_INTERNAL_CELLSELECT" "ACAD_INTERNAL_REPEATCELLEDIT" "ACADBLOCKDIALOG" "ACADWBLOCKDIALOG" "adc" "adcclose" "adccustomnavigate" "adcenter" "adcnavigate" "AecDisplayManagerConfigsSelection" "AecFileOpenMessage" "AecFileSaveMessage" "AecObjectCopyMessage" "AecObjRelDump" "AecObjRelShow" "AecObjRelUpdate" "AecPostDxfinFix" "AecSetXrefConfig" "AecVersion" "AIDIMFLIPARROW" "AIDIMPREC" "AIDIMSTYLE" "AIDIMTEXTMOVE" "ALIGN" "ANIPATH" "APPLOAD" "ARCHIVE" "ARCTEXT" "ARRAY" "ASSIST" "ASSISTCLOSE" "ATEXT" "ATTACHURL" "ATTEDIT" "ATTSYNC" "BACTION" "BACTIONSET" "BACTIONTOOL" "BASSOCIATE" "BATTMAN" "BATTORDER" "BAUTHORPALETTE" "BAUTHORPALETTECLOSE" "BCLOSE" "BCYCLEORDER" "BEDIT" "BGPLOTRECEIVE" "BGRIPSET" "BLOCKICON" "BlookupTable" "BMAKE" "BMOD" "BPARAMETER" "BROWSER" "BROWSER2" "BSAVE" "BSAVEAS" "BVHIDE" "BVSHOW" "BVSTATE" "cal" "CAMERA" "CHECKSTANDARDS" "CHSPACE" "CLASSICIMAGE" "content" "CONVERTCTB" "CONVERTOLDLIGHTS" "CONVERTOLDMATERIALS" "CONVERTPSTYLES" "COPYTOLAYER" "cui" "cuiexport" "cuiimport" "DASHBOARD" "DASHBOARDCLOSE" "DBCCONFIGURE" "DBCCONNECT" "DBCDEFINELLT" "DBCDEFINELT" "DBCDELETELABELS" "DBCDELETELINKS" "DBCDELETELLT" "DBCDELETELT" "DBCDELETEQRY" "DBCDISCONNECT" "DBCEDITLINKEDTABLE" "DBCEDITLLT" "DBCEDITLT" "DBCEDITQRY" "DBCEDITTABLE" "DBCEXECUTEQRY" "DBCEXPORTLINKS" "DBCEXPORTQS" "DBCEXPORTTS" "DBCHIDELABELS" "DBCIMPORTQRY" "DBCIMPORTQS" "DBCIMPORTTS" "DBCLINKCONVERSION" "DBCLINKMANAGER" "DBCNEWQRYLT" "DBCNEWQRYTABLE" "DBCONNECT" "DBCPROPSLBLT" "DBCPROPSLT" "DBCRELOADLABELS" "DBCSELECTLINKS" "DBCSHOWLABELS" "DBCSYNC" "DBCVIEWLINKEDTABLE" "DBCVIEWTABLE" "DDATTE" "DDIM" "DDINSERT" "DDPLOTSTAMP" "DDPTYPE" "DDUNITS" "DDVPOINT" "DETACHURL" "DIM" "DIM1" "DIMALIGNED" "DIMANGULAR" "DIMARC" "DIMBASELINE" "DIMCENTER" "DIMCONTINUE" "DIMDIAMETER" "DIMDISASSOCIATE" "DIMEDIT" "DIMEX" "DIMHORIZONTAL" "DIMIM" "DIMJOGGED" "DIMLINEAR" "DIMORDINATE" "DIMOVERRIDE" "DIMRADIUS" "DIMREASSOCIATE" "DIMREGEN" "DIMROTATED" "DIMSTYLE" "DIMTEDIT" "DIMVERTICAL" "DISTANTLIGHT" "DRAWINGRECOVERY" "DRAWINGRECOVERYHIDE" "DRAWORDER" "DSETTINGS" "DWFADJUST" "DWFATTACH" "DWFCLIP" "DWGPROPS" "EATTEDIT" "EATTEXT" "EATTEXTEDIT" "EATTEXTUPDATE" "EPLOTEXT" "ETRANSMIT" "ExacReload" "ExternalReferences" "ExternalReferencesClose" "FIELD" "FILTER" "FIND" "FLATSHOT" "GEOGRAPHICLOCATION" "HELIX" "HIDE" "HYPERLINK" "HYPERLINKBACK" "HYPERLINKFWD" "HYPERLINKOPEN" "HYPERLINKOPTIONS" "HYPERLINKSTOP" "IMAGE" "IMAGEADJUST" "IMAGEATTACH" "IMAGECLIP" "IMAGEFRAME" "IMAGEQUALITY" "INTERFERE" "INTERNALTABLEDIT" "JOGSECTION" "JUSTIFYTEXT" "LAYCUR" "LAYDEL" "LAYER" "LAYERP" "LAYERPMODE" "LAYFRZ" "LAYISO" "LAYLCK" "LAYMCH" "LAYMRG" "LAYOFF" "LAYON" "LAYTHW" "LAYTRANS" "LAYULK" "LAYUNISO" "LAYVPI" "LAYWALK" "LEADER" "LIGHT" "LIGHTLIST" "LIGHTLISTCLOSE" "LIVESECTION" "MARKUP" "MARKUPCLOSE" "MATCHCELL" "MATCHPROP" "MATERIALASSIGN" "MATERIALATTACH" "MATERIALMAP" "MATERIALS" "MATERIALSCLOSE" "MIRROR3D" "MLEDIT" "MLSTYLE" "MOCORO" "MOVEBAK" "MTEDIT" "MTEXT" "MTPROP" "NETLOAD" "NEWSHEETSET" "NEWVIEW" "OLECONVERT" "OLEOPEN" "OLERESET" "OLESCALE" "OPENDWFMARKUP" "OPENSHEETSET" "PAINTER" "PAINTPROP" "PASTEASHYPERLINK" "PLOTSTAMP" "POINTLIGHT" "PPGETACADINPUT" "PROPERTIES" "PROPERTIESCLOSE" "PROPULATE" "PUBLISH" "PUBLISHTOWEB" "PURGE" "qcclose" "QDIM" "QLATTACH" "QLATTACHSET" "QLDETACHSET" "QLEADER" "QSELECT" "quickcalc" "RECTANG" "RECTANGLE" "REFCLOSE" "REFEDIT" "REFSAVE" "REFSET" "RENDER" "RENDERCROP" "RENDERENVIRONMENT" "RENDERPRESETS" "RENDERWIN" "RESETBLOCK" "REVCLOUD" "ROTATE3D" "RPREF" "RPREFCLOSE" "RTEXT" "SAVEIMG" "ScaleListEdit" "SCALETEXT" "SECTIONPLANE" "SECURITYOPTIONS" "SELECTURL" "Setidrophandler" "SHADE" "SHADEMODE" "SHEETSET" "SHEETSETHIDE" "SIGVALIDATE" "SOLDRAW" "SOLPROF" "SOLVIEW" "SPACETRANS" "SPOTLIGHT" "STANDARDS" "SUNPROPERTIES" "SUNPROPERTIESCLOSE" "SYSVDLG" "TABLE" "TABLEDIT" "TABLEEXPORT" "TABLESTYLE" "TaskBar" "TEXTTOFRONT" "TINSERT" "TOLERANCE" "TOOLPALETTES" "TOOLPALETTESCLOSE" "TRANSPARENCY" "TXT2MTXT" "UNITS" "UPDATEFIELD" "UPDATETHUMBSNOW" "VBAIDE" "VBALOAD" "VBAMAN" "VBANEW" "VBAPREF" "VBARUN" "VBASTMT" "VBAUNLOAD" "VIEW" "VIEWPLOTDETAILS" "VISUALSTYLES" "VISUALSTYLESCLOSE" "VPMAX" "VPMIN" "VTOPTIONS" "WALKFLYSETTINGS" "WHOHAS" "WIPEOUT" "XOPEN" "XP" "XPLODE" ) you can use vl-position , member etc.. (defun bar (cmd) (vl-some ''((x) (wcmatch ([color="blue"]strcase[/color] x) (strcat (strcase cmd)"*"))) (appcom))) _$ (bar "eattedit") T Edited April 13, 2018 by hanhphuc strcase Quote Link to comment Share on other sites More sharing options...
Grrr Posted April 15, 2018 Share Posted April 15, 2018 Good job, hanhphuc! You impressed me one more time.. Quote Link to comment Share on other sites More sharing options...
rlx Posted April 15, 2018 Share Posted April 15, 2018 (edited) Noticed that vlax-product-key can contain an addition code so by removing it you get the result you want. ; hanhphuc 13.04.2018 (defun appcom ( / key pk i l lst ) (if (setq i (vl-string-position (ascii ":") (setq pk (vlax-product-key)))) (setq pk (substr pk 1 i))) (setq key (strcat "HKEY_LOCAL_MACHINE\\" pk "\\Applications\\")) (cdr (acad_strlsort (apply 'append (mapcar ''((app) (vl-registry-descendents (strcat key app "\\Commands") app))(vl-registry-descendents key)))))) this probably also would do the trick : (vl-registry-descendents (strcat "HKEY_LOCAL_MACHINE\\" (if (setq i (vl-string-position (ascii ":") (setq pk (vlax-product-key)))) (substr pk 1 i) pk) "\\Applications\\")) Edited April 16, 2018 by rlx Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted April 16, 2018 Share Posted April 16, 2018 @grrr thanks but it was VL trick respond "OP's topic - list the commands" not worth flettery but what MP's listing code was really impressed!! After all Roy's solution is more relevant as it met "KISS" principle @rlx IMO registry path product-key maybe varies due to different version ,thanks anyway (defun appcom ( / key [b][color="red"]l lst[/color][/b] ) [color="green"];<-- the [color="red"]l lst[/color] variables unused can be removed.[/color] The reason was initially using [color="blue"]foreach[/color] later changed to [color="blue"]mapcar[/color]... Quote Link to comment Share on other sites More sharing options...
