jason_a Posted June 22, 2017 Posted June 22, 2017 Hello, I currently have a lisp routine that will look for a specific sized hole and change it to a different diameter. It also performs some layer management. I'm having a bit of trouble trying to modify the routine so that it will look for a range instead of a specific value. So in my case, i'd like to look for any holes that are between 5.1 to 5.3mm in diameter and change them to 5.0mm. Thank you. ; Find 5.1mm hole and change to proper layer and 5mm diameter hole (setq AA 5.1) (setq BB 5.0000) (if (ssget "_X" (list '(0 . "CIRCLE")(cons 40 (/ AA 2.0)))) (progn (COMMAND "CHPROP" "P" "" "P" "LA" "VERTICAL15P00" "") (setq ss1 (ssget "_X" (list '(0 . "CIRCLE")(cons 40 (/ AA 2.0))))) (setq LE (sslength ss1)) (setq CNT 0) (while (< CNT LE) (progn (setq OBJ (entget (ssname ss1 CNT))) (setq NewScale (* (cdr (assoc 40 OBJ)) (/ BB AA))) (setq OBJ (subst (cons 40 NewScale) (assoc 40 OBJ) OBJ )) (entmod OBJ) (setq CNT (+ CNT 1)) )))) Quote
pkenewell Posted June 22, 2017 Posted June 22, 2017 (edited) Try Changing (setq AA 5.1) to (setq AA 5.1 AB 5.3) and (ssget "_X" (list '(0 . "CIRCLE")(cons 40 (/ AA 2.0)))) to (ssget "_X" (list '(0 . "CIRCLE") '(-4 . "<OR") (cons 40 (/ AA 2.0)) (cons 40 (/ AB 2)) '(-4 . "OR>"))) CORRECTION: If you want to select the full range between AA and AB, it would be the following: (ssget "_X" (list '(0 . "CIRCLE") '(-4 . "<AND") '(-4 . ">=") (cons 40 (/ AA 2.0)) '(-4 . "<=") (cons 40 (/ AB 2)) '(-4 . "AND>") )) I'm not sure what you are doing here also but it would need to be changed I think: (setq NewScale (* (cdr (assoc 40 OBJ)) (/ BB AA))) based on your original description, would you not just want to do this? (setq NewScale (/ BB 2)) Here is what I recommend for you code: (setq AA 5.1 AB 5.3 BB 5.0 lyr "VERTICAL15P00") (if (setq ss1 (ssget "_X" (list '(0 . "CIRCLE") '(-4 . "<AND") '(-4 . ">=") (cons 40 (/ AA 2.0)) '(-4 . "<=") (cons 40 (/ AB 2)) '(-4 . "AND>") ))) (progn (setq LE (sslength ss1) CNT 0) (while (< CNT LE) (progn (setq OBJ (entget (ssname ss1 CNT)) OBJ (subst (cons 40 (/ bb 2)) (assoc 40 OBJ) OBJ) ; Change Radius OBJ (subst (cons 8 lyr) (assoc 8 OBJ) OBJ) ;Change Layer Name CNT (1+ CNT) ) (entmod OBJ) ) ) ) ) EDIT: OOPS - I got the logic wrong so I am changing this to be helpful for someone else in the future. Edited June 23, 2017 by pkenewell Quote
jason_a Posted June 22, 2017 Author Posted June 22, 2017 (edited) Thank you, this almost works as intended based on your code. The only problem is that it is converting all sized holes in the drawing, not just the ones within the range. So anything outside of the range is also affected. Any ideas? EDIT. I changed the OR functions to AND. Also added a few more lines of code. Seems to be working now. Thanks for your help! ; Find 5.1mm hole and change to proper layer and 5mm diameter hole (setq AA 5.1 AB 5.3) (setq BB 5.0000) (if (ssget "_X" (list '(0 . "CIRCLE") '(-4 . "<AND") '(-4 . ">=") (cons 40 (/ AA 2.0)) '(-4 . "<=") (cons 40 (/ AB 2.0)) '(-4 . "AND>") )) (progn (COMMAND "CHPROP" "P" "" "P" "LA" "VERTICAL15P00" "") (setq ss1 (ssget "_X" (list '(0 . "CIRCLE") '(-4 . "<AND") '(-4 . ">=") (cons 40 (/ AA 2.0)) '(-4 . "<=") (cons 40 (/ AB 2.0)) '(-4 . "AND>") ))) (setq LE (sslength ss1)) (setq CNT 0) (while (< CNT LE) (progn (setq OBJ (entget (ssname ss1 CNT))) (setq NewScale (/ BB 2)) (setq OBJ (subst (cons 40 NewScale) (assoc 40 OBJ) OBJ )) (entmod OBJ) (setq CNT (+ CNT 1)) )))) Edited June 22, 2017 by jason_a Quote
pkenewell Posted June 23, 2017 Posted June 23, 2017 I changed the OR functions to AND. Also added a few more lines of code. Seems to be working now. Thanks for your help! Oops - Well I am glad you figured out the logic. Glad to have helped. BTW. Did you notice in my code that I eliminated the need for 2 SSGET calls and the CHPROP command? The 2nd SSGET call is not necessary as you can save the selection set on your first call. Also - unless CHPROP does something else for you besides changing the layer name of the Circles, it is better to avoid the command call for something so simple. Quote
jason_a Posted June 24, 2017 Author Posted June 24, 2017 Yes I now notice the elimination of the CHPROP command in your lisp routine. I've now incorporated your snippet of code into mine. As for the two ssget calls, i've kept them seperated just so it's easier for me to read and edit as I copy and expand the code to cover more hole sizes. Thanks again! ; Find holes in 4.8mm-5.3mm diameter range, convert to 5mm diameter and change to proper layer (setq AA 4.8 AB 5.3) ;Diameter range (setq BB 5.0 lyr "VERTICAL15P00") ;New diameter and layer name (if (ssget "_X" (list '(0 . "CIRCLE") '(-4 . "<AND") '(-4 . ">=") (cons 40 (/ AA 2.0)) '(-4 . "<=") (cons 40 (/ AB 2.0)) '(-4 . "AND>") )) (progn (setq ss1 (ssget "_X" (list '(0 . "CIRCLE") '(-4 . "<AND") '(-4 . ">=") (cons 40 (/ AA 2.0)) ; greater than or equal to '(-4 . "<=") (cons 40 (/ AB 2.0)) ; less than or equal to '(-4 . "AND>") ))) (setq LE (sslength ss1)) (setq CNT 0) (while (< CNT LE) (progn (setq LE (sslength ss1) CNT 0) (while (< CNT LE) (progn (setq OBJ (entget (ssname ss1 CNT)) OBJ (subst (cons 40 (/ BB 2)) (assoc 40 OBJ) OBJ) ; Change Radius OBJ (subst (cons 8 lyr) (assoc 8 OBJ) OBJ) ; Change Layer Name CNT (1+ CNT) ) (entmod OBJ) ) ) )))) Quote
