ziele_o2k Posted June 24, 2017 Posted June 24, 2017 How to delete area marked as red rectangle? but : button { width = 13; fixed_width = true; } StdQuickOptionsDialog : dialog { label = "Quick settings"; : column { : row {alignment = centered; : column { alignment = left; : text { key = "A1";label = "Settings 1 question longer and";} : text { key = "A2";label = "Settings 2";} : text { key = "A3";label = "Settings 3";} } : column { alignment = right;width= 25; : edit_box { key = "edit1";} : popup_list { key = "pop";} : edit_box { key = "edit2";} } } : spacer {} : spacer {} : row { alignment = centered; fixed_width = true; : but { key = "but3";label = "&Save"; } : but { key = "but1";label = "&Ok"; is_default = true; } : but { key = "but2";label = "&Cancel"; is_cancel = true; } } : errtile {} } } Quote
BIGAL Posted June 25, 2017 Posted June 25, 2017 I swapped the two columns order the text appears now on right but close to edit box ? DCL does some stuff that over rides have you a copy of the manual about creating DCL's it is under help may give some clues. Quote
ziele_o2k Posted June 25, 2017 Author Posted June 25, 2017 I swapped the two columns order the text appears now on right but close to edit box ? DCL does some stuff that over rides have you a copy of the manual about creating DCL's it is under help may give some clues. You only moved blank space.. that is not a solution.. Anyway, my problem is solved. but : button { width = 13; fixed_width = true; } StdQuickOptionsDialog : dialog { label = "Quick settings"; : column { : row {alignment = centered;width=30; : column { alignment = left; : text { key = "A1";value = "Settings 1 question longer and";width=24;} : text { key = "A2";value = "Settings 2";} : text { key = "A3";value = "Settings 3";} } : column { alignment = right; : edit_box { key = "edit1";width=15;} : popup_list { key = "pop";} : edit_box { key = "edit2";} } } : spacer_1 {} : row { alignment = centered; fixed_width = true; : but { key = "but3";label = "&Save"; } : but { key = "but1";label = "&Ok"; is_default = true; } : but { key = "but2";label = "&Cancel"; is_cancel = true; } } : errtile {} } } Quote
