Hi Everyone..Could anyone please tell me, how to select all red colored text and mtext from model space through lisp.
Thanks in advance.
(sssetfirst nil (ssget "_x" '((0 . "TEXT,MTEXT") (62 . 1))))
(setq ss (ssget "X" '((0 . "text,mtext")(62 . 1))))
or
(setq ss (ssget "X" (list (cons 0 "TEXT,MTEXT")(cons 62 1))))
Hi All,
Thanks for your quick reply.. Need one more help..how can change selected text and mtext to BOLD.
Made a quick search. Found something from Grand Master Lee Mac. Hope it helps.
;; Args:-
;; tStyle  ~  Valid TextStyle Name
;; flags [bit-coded]
;; 0  ~  Regular
;; 1  ~  Bold
;; 2  ~  Italic
(defun PutFontStyle (tStyle flags / TypeFace Bold Italic CharSet P&Fam)
 (vl-load-com) ;; Lee Mac  ~  19.02.10
 (if (not (vl-catch-all-error-p
            (setq tStyle
              (vl-catch-all-apply
                (function vla-Item)
                  (list (vla-get-TextStyles
                          (vla-get-ActiveDocument
                            (vlax-get-acad-object))) tStyle)))))
     (vla-getFont tStyle 'TypeFace 'Bold 'Italic 'CharSet 'P&Fam)
     (vla-SetFont tStyle  TypeFace
       (if (= 1 (logand 1 flags)) :vlax-true :vlax-false)
       (if (= 2 (logand 2 flags)) :vlax-true :vlax-false) CharSet P&Fam) t)))
Example of Usage:
(PutFontStyle "myStyle" 3) ;  ~  Sets the font for 'MyStyle' textstyle to Bold & Italic.
Hi tmelancon,
Thanks for your effort..I have tried this one..but in this code we have to select the object as manually..i need select all red colored text and mtext and change to BOLD.
Can you modify the lisp.
Do a search here for modifying mtext there is some good coding examples of finding even a single word that is red and changing its colour etc. The coding uses direct modification of the hidden code in mtext. Bold is an item that can be added.
HEADING
TextString = "{\\fArial|b0|i0|c0|p34;HE\\fArial|b1|i0|c0|p34;ADI\\fArial|b0|i0|c0|p34;NG}"
Only thing I found and edited a little bit is this. I am going to keep at it. I am just trying to select all RED, MTEXT, TEXT but in VL.
(defun c:mtval( / ent objmtext stroldval strnewval)
 (setq ent (car (entsel))
 objMText (vlax-ename->vla-object ent)
 strOldval (vlax-get-property objMText "TEXTSTRING")
 strnewval (STRCAT "{\\fArial|b1|i0|c0|p34;" stroldval)
 (if strnewval (vlax-put-property objmtext "TEXTSTRING" strnewval)
 (vlax-release-object objmtext)
Be careful when adding these hard coded values .. you could make a real mess if you don't check for existing: "{\\fArial|b1|i0|c0|p34;{\\fArial|b1|i0|c0|p34;{\\fArial|b1|i0|c0|p34;{\\fArial|b1|i0|c0|p34;asdfsafsdfsaff"
Maybe use something like this:
(strcat "{\\fArial|b1|i0|c0|p34;"
		  (vl-string-left-trim
		    (vlax-get-property objmtext "TEXTSTRING")
Wow see... perfect example of me being a beginner programmer and getting ahead of myself just because the result on the "surface" seems legit.. Thank you for that input I definitely need to discipline myself more to double-triple check everything when it comes to these routines. This code is so close to doing what the op is looking for. The problem I am having is when I edit it to Selected all MTEXT with color red I get an error "Error: bad argument type: VLA-OBJECT nil". I am sure its a crossover issue.
Try this .. it filters out text that is currently bold so you don't have to check in the loop :)
(defun c:hcb (/ _ps->ss o ss)
 ;; Use a function like this to convert a selection set to a list of items
 (defun _ps->ss (ps)
   (if	(= 'pickset (type ps))
     (vl-remove-if 'listp (mapcar 'cadr (ssnamex ps)))
 (if (setq ss (_ps->ss (ssget ":L" '((0 . "mtext") (1 . "~{\\fArial|b1|i0|c0|p34;*")))))
   (foreach mtext ss
     (setq o (vlax-ename->vla-object mtext))
     (vla-put-textstring o (strcat "{\\fArial|b1|i0|c0|p34;" (vla-get-textstring o)))
Wow yea look at that. Hope you dont mind but I took your code and modified it slightly to give the OP exactly what he/she was looking for:
 (defun _ps->ss (ps)
 (if (setq ss (_ps->ss (ssget [color=red]"X"[/color] '((0 . "mtext") (1 . "~{\\fArial|b1|i0|c0|p34;*")[color=red](62 . 1)[/color]))))
   (foreach mtext ss
gmmdinesh, copy and paste this code into your main file. Run it and I think you will find it is exactly what you are looking for. Plus all the extra benefits Ron added. Hope you like.
gmmdinesh, has this worked for you? Please post either way so anyone else viewing will know. Thanks.
