ktbjx Posted October 21, 2017 Posted October 21, 2017 i have a list here that exports XYZ Length Angle But now i want to export only the MidPoint of every Line, can someone Help Me? (defun c:LINEEXTRACTION ( / d e f i s spt ept) (if (and (setq s (ssget '((0 . "LINE")))) (setq f (getfiled "" "" "CSV" 1)) (setq d (open f "w")) ) (progn (write-line "Start X,Start Y,Start Z,End X,End Y, End Z,Group,Length,Angle" d) (repeat (setq i (sslength s)) (setq e (entget (ssname s (setq i (1- i)))) spt (cdr (assoc 10 e)) ept (cdr (assoc 11 e)) ) (write-line (LM:lst->str (append (mapcar 'rtos (cdr (assoc 10 e))) (mapcar 'rtos (cdr (assoc 11 e))) (if (and (setq e (member '(102 . "{ACAD_REACTORS") e)) (setq e (member '(102 . "{ACAD_REACTORS") (entget (setq x (cdr (assoc 330 e)))))) (setq e (cdr (assoc 3 (member (cons 350 x) (reverse (entget (cdr (assoc 330 e)))))))) ) (list e) ) ) "," ) d ) ) (close d) ) ) (prompt "DONE!") (princ) ) (defun LM:lst->str ( lst del ) (if (cdr lst) (strcat (car lst) del (LM:lst->str (cdr lst) del) "," (rtos (distance spt ept)) "," (angtos (angle spt ept)) ) (car lst) ) ) (princ) Quote
BIGAL Posted October 21, 2017 Posted October 21, 2017 ktbjx no offence but you have all the answers in front of you, have a go at doing it, you have pt1 xyz pt2 xzy the 3d mid pt is just simple maths MidX=(pt1x+pt2x)/2 and so on. Big hint spt (cdr (assoc 10 e)) ept (cdr (assoc 11 e)) further delving x = car y=cadr z=caddr Quote
hanhphuc Posted October 23, 2017 Posted October 23, 2017 *line only not arc, point, etc.. (defun foo (e) (vlax-curve-getPointAtParam e (/ (vlax-curve-getEndParam e) 2.))) WCS Quote
