Hi Designers,
I would like to have a lisp that reads the Description of a Block and shows it on a Multileader so then you don't have to type in the Text once a Block is registered.
I know this topic was covered in an much older post before - almost 10 years ago - but I put hours experimenting with the Lisp in different ways and still couldn't get it to work 100%.
http://www.cadtutor.net/forum/showthread.php?39301-Block-into-multileader-text
Does anyone have the solution to this?
Here is what I wrote:
- the client selects a block (I assume it has a description, I assume the client clicks on a block ... no anti dummy protection)
- the client must now draw the MLeader: two points: arrow head + leader landing
- The routine will fill in the caption, being the description of the block.
Command: SAD (pun maybe intended, although it's just an abbreviation)
(defun getBlockProperties ( #Entsel / )
     (setq #Entsel   (vlax-ename->vla-object (car #Entsel))
           ;; insertion point
           #InsPoint (vlax-safearray->list
                       (vlax-variant-value
                         (vla-get-InsertionPoint #Entsel)
                       ) ;_ vlax-variant-value
                     ) ;_ vlax-safearray->list
           ;; block name
           #Name     (vla-get-name #Entsel)
           ;; block description
           #Desc     (vla-get-comments
                       (vla-item
                         (vla-get-blocks
                           (vla-get-activedocument (vlax-get-acad-object))
                         ) ;_ vla-get-blocks
                         #Name
                       ) ;_ vla-item
                     ) ;_ vla-get-comments
     ) ;_ setq
 (list #Name #InsPoint #Desc)
;; create Mleader with caption.
(defun wmt (caption / )
 ;;(vl-cmdf "_.MLEADER" PAUSE PAUSE "" "_.TEXTEDIT" "_L")
 (vl-cmdf "_.MLEADER" PAUSE PAUSE  caption)
;; Select And get Description
(defun c:sad ( / desc)
 (setq desc (nth 2 (getBlockProperties (entsel "\nSelect a block: "))))
 (princ "\nNow draw the MLeader:\n")
 (wmt desc)
Happy with this?
Almost !
It identifies the Description, but won't fill in the caption. :(
The simplest I guess.
(defun c:d2ml ( / s d)
 (and (princ "\nPick a block :")
      (setq s (ssget "_+.:S:E" '((0 . "INSERT"))))
      (or (setq d (cdr (assoc 4 (entget (tblobjname "BLOCK" (cdr (assoc 2 (entget (ssname s 0)))))))))
          (alert "Block does not have a description <!>")
      (vl-cmdf "_.Mleader" "\\" "\\" d)
Same result.
I don't know why it won't put in the Description..
Same result.
Can you post a drawing including the block?
Just this a go and let me know.
(defun c:d2ml ( / s d l n e)
      (setq l (entlast))
      (vl-cmdf "_.Mleader" "\\" "\\" "")
      (and (not (= l (setq n (entlast))))
           (entmod (subst (cons 304 d) (assoc 304 (setq e (entget n))) e))
You are a Legend Tharwat !!
It's works perfectly, many thanks for that ! :D
And you Emanuel for giving it a go, I appreciate it.
Thanks for the nice words AlexP.
You are welcome anytime. :)
