Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > AutoCAD > AutoCAD Beginners' Area
Closed Thread
Thread Tools
Old 7th May 2008, 07:41 pm   #1
CADTutor
Administrator
CADTutor's Avatar
Using: AutoCAD 2010
FAQ Article Autodesk Student Software
Student Software
Q: I'm a student, can I get AutoCAD and other Autodesk software for free?
A: Yes, you can.
You can download free full-working versions of Autodesk software from the Autodesk Student Community site provided you are a registered student at a recognised college or university.
In order to prove you are a registered student, you will need to sign up at the Student Community site using your college or university email address.
Getting the software
To get your free software, follow the link above to the Student Community site and sign-up using the email address given to you by your college or university.
Your log-in details will be sent to the email address you used to sign-up. Once you have them, you can log-in and go to the Software Downloads page. There, you will find a long list of downloads. Try them all if you want but make sure you have a fast internet connection; some of the downloads are over a gigabyte!
Student editions
Although the available applications are full working versions, they are student editions and are not the same as commercial versions. For example, they can only be used for 12 months - that's fine if you are still a student in 12 month's time because you can just download a newer version. Also, some of the applications may have overprints. AutoCAD will print a border around any print that says "PRODUCED BY AN AUTODESK EDUCATIONAL PRODUCT ". Saved DWG files will also be marked as the same and will cause an alert if opened in a commercial product.
Do bear in mind that the educational license for these products does not allow their use for commercial purposes.
Available Software
At the time of writing (May 2009), the following are available for download:
Revit Architecture
Revit Structure
Autodesk Robot Structural Analysis Professional
Revit MEP
Autodesk Navisworks Manage
Autodesk Ecotect
Green Building Studio (web based service)
AutoCAD (vanilla)
AutoCAD Architecture
AutoCAD Civil 3D
AutoCAD Electrical
AutoCAD Inventor Professional
AutoCAD Map 3D
AutoCAD Mechanical
AutoCAD MEP
AutoCAD Raster Design
Autodesk 3ds Max (30-day trial only)
Autodesk Alias Automotive
Autodesk Impression
Autodesk Maya (30-day trial only)
Autodesk MotionBuilder
Autodesk Mudbox (30-day trial only)
Autodesk Showcase
Autodesk SketchBook Pro
Autodesk VIZ
As of the 2010 versions, vanilla AutoCAD is available and not just the vertical products.
Serial number
When your software is installed, you will need to register it using the serial number provided to you at the time of download. Don't worry if you lose your serial number, it can be found against the software you downloaded any time you log-in. Further instructions can be found at the Autodesk Student Community site.
Don't forget, you will also find lots of helpful support materials at the Student Community site in addition to the downloads.
Last edited by CADTutor : 7th May 2009 at 12:50 pm. Reason: Updated for 2010 versions
Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
CADTutor is offline
Closed Thread
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Which autodesk software for cabinets? Lucid AutoCAD Drawing Management & Output 4 26th Nov 2007 01:05 pm
Autodesk Student Community jdkriek Useful Links 3 20th Nov 2007 10:43 am
Attention Students and Teachers...Free Autodesk Software and Education Support! Between the Lines AutoCAD RSS Feeds 0 3rd Jul 2007 09:40 pm
Free AutoDesk software? ReMark Software & Licensing 3 18th Nov 2006 12:31 am
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
