attaching to lines
Hi All,
very simple question!
I have 2 lines which the second one has started from the end point of the first one.
how do I put them together as one object.
Cheers
Ali
Try the PEDIT command
if the lines are collinear, join will work
Or you can avoid the PEDIT (join) altogether and and create the two lines with PLINE (polyline) when drawing.
thank u All,
I knew PE but let me explain the situation more,
I received a drawing which is drawn in a strange way!!!
instead of having a line from A to B, I have 2 or more lines in between. So when I want to select that line I have to be careful to select all of them. What I'm looking for is a command to join them and make them as one object (like join in PE) but change that in to a line which has just one start point at A and one end point at B.
Cheers
Ali
OVERKILL will do it. See its options.
I was just thinking you are joking :D with "OVERKILL"
but after I checked it, I really like it. that was cooool8)
Cheers
