Communications Center hangs up, freezes Autocad 2010
I am using AutoCAD 2010 along with Raster Design and when I go to access the Communications Center Icon, the pull down menu starts to show and then hangs. After a second or two AutoCAD then freezes up. I also had the same problem with 2009 but figured the new release would correct it. This is a stand alone license. My co-worker can access his without this problem. Any help would be greatly appreciated.
CommCenter.doc
  • 10 months later...
This fixed mine,
Try this fix,
Open Start>Control Panels>Internet Options: Advanced and activate (check box)
* Disable Script Debugging (Internet Explorer)
* Disable Script Debuggung (Other)
