warren architecture Posted July 3, 2009 Posted July 3, 2009 dose anyone render in AA '09/'10? If so, is it easy to do? I've just used Sketchup to do my renderings because it's so simple to do. I've been told to use other software i.e sketch up with the VRAY plugin? But I've notice that there's no viz render when I've installed both AA '09 and AA '10? have autodesk removed these packages from the installation. Quote
Cad64 Posted July 17, 2009 Posted July 17, 2009 Viz has been discontinued. The last version was Viz 2008. It has been replaced by 3DS Max Design. Quote
CADMASTER1128 Posted July 17, 2009 Posted July 17, 2009 dose anyone render in AA '09/'10? If so, is it easy to do? I've just used Sketchup to do my renderings because it's so simple to do. I've been told to use other software i.e sketch up with the VRAY plugin? But I've notice that there's no viz render when I've installed both AA '09 and AA '10? have autodesk removed these packages from the installation. I have a basic tutorial for AA 08. This should be the same basic idea for 09/10 of which I have both if you need to modify it for you. This tutorial is for the basic rendering of a house and isn't made to create detailed renderings like seen here on CADTutor. Quote
