#1 |
Full Member
![]() ![]() Using: AutoCAD 2009 Join Date: Sep 2009
I'm also looking for a procedure to move an object parallel to an axis and match a start point with the x,y, or z-coordinate af another point while keeping the other coordinates.
Code:
defun c: txp (translate in x-direction to a certain point), typ, tzp select objects select point 1 (x1,y1,z1) select point 2 (x2) move objects (x1,y1,z1) (x2,y1,z1) ? |
#2 |
Super Member
![]() ![]() ![]() ![]() Using: Civil 3D 2009 Join Date: Apr 2008
LoL
I'm not sure I understand what you are asking. Sounds like something that can be solved with point filters. Shouldn't be too terribly difficult. I don't mind helping, but I'm not sure I understand what you want. |
Seann: ...it went crazy ex-girlfriend on me...
eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak... |
#3 |
Super Member
Is this what you are shooting for?
MXY.gif You could also achieve this by turning orthomode on. Might as well post this. I know it's not what you were looking for, but someone might want it. Code:
(defun c:MXY (/ #SS #Pnt #Choice)
(and (setq #SS (ssget "_:L"))
(setq #Pnt (getpoint "\nSpecity base point: "))
(not (initget 0 "X Y"))
(setq #Choice (getkword "\nAxis filter [X/Y]: "))
(command "_.move" #SS "" "_non" #Pnt (strcat "." #Choice) "_non" #Pnt)
) ;_ and
) ;_ defun
#4 |
Full Member
Edit: Bad example.
#5 |
Full Member
OK, a better example. And a real one.
In top view, I've positioned a table in my house model. As I change to ISO-view, I find that the table hovers somewhere above the floor. No I would like to enter "tzp", click on any foot of a table leg and then on any corner of the floor. The table would drop to the floor without changing its position in the ground plan. I hope that does it. I admit that above descriptions were a bit weird. Thanks for your understanding. Last edited by Randolph : 1st Nov 2009 at 08:18 pm. |
#6 | |
Super Member
Quote:
2. Single or multiple objects? |
#7 |
Full Member
Mostly 3D Solids, but also 2D objects. Multiple would be better, as the "table" might consist of several solids.
#8 |
Super Member
So it's no different than selecting an object, picking a point, using .XY filter, then picking another point to get the Z value?
Code:
Command: m MOVE Select objects: Specify opposite corner: 1 found Select objects: Specify base point or [Displacement] <Displacement>: _endp of Specify second point or <use first point as displacement>: .XY of _endp of (need Z): _endp of |
#9 |
Super Member
#10 |
Full Member
"So it's no different than selecting an object, picking a point, using .XY filter, then picking another point to get the Z value?"
Yeah, you got it, but in 1 command and also for the other axis (txp, typ, tzp). As I wrote in the first posting: move objects from point (x1,y1,z1) to point (x1, y1, z2). It's no more complicated. |
| Thread Tools | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| List coordinate by select point group | jason tay | AutoLISP, VBA, the CUI & Customisation | 37 | 27th Apr 2009 12:36 am |
| How to retrive 3D coordinate information of any object from AutoCAD VBA | Kshirsagar | AutoLISP, VBA, the CUI & Customisation | 3 | 11th Nov 2008 11:59 am |
| Block, Object/Match properties question. | p1nkninja | AutoCAD Beginners' Area | 4 | 12th Oct 2008 03:22 am |
| PHOTO MATCH - how to start with single point perspective? | Strix | SketchUp | 4 | 27th Aug 2007 11:35 pm |
| how to move origin point ? | airs | AutoCAD Beginners' Area | 2 | 20th Nov 2006 12:52 am |
