#1 |
Junior Member
![]() Using: AutoCAD 2000 Join Date: Nov 2009
Hi,
Part of my job involves me drawing roofs. I sometimes need to squash or stretch these 2-D drawings to show the roof from diferent angles. More simply - I have a 2D drawing made up for simple lines, rectangles and circles which I would like to squash or stretch along one plane. Not along both x- and y-axes. Any ideas? Thanks! Ben |
#2 |
Super Member
![]() ![]() ![]() ![]() Using: AutoCAD 2010 Join Date: Feb 2006
Have you looked at using dynamic blocks? Look at using the stretch parameter
AutoCAD 2010
'"Accept that some days you're the pigeon, and some days you're the statue." |
#3 |
Forum Deity
![]() ![]() ![]() ![]() ![]() Using: Electrical 2008 Join Date: Nov 2005
or a standard block and use the properties palette to vary the X & Y scales.
Dave
#4 |
Junior Member
Yes! dbroada. Adjusting the scales on the block properties worked a treat. That is going to save me so much time. I was stretching each individual object and its location...
I will have also have a look at dynamic blocks. Thanks guys. |
#5 |
Quantum Mechanic
If you are still using AutoCAD 2000 then you will not have the Dynamic Block feature. This was added later.
Education is a lifelong process. |
#6 |
Super Member
![]() ![]() ![]() ![]() Using: Mechanical 2009 Join Date: Feb 2007
A couple of other options- you could use MSTRETCH, or you could select multiple grips holding down <SHIFT> while selecting them.
However, I have no idea as to when these options were introduced? |
"To alcohol; the cause and solution to all of life's problems." - Homer Simpson
| Thread Tools | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| COPY or ** COPY ** - Copy and Stretch, Move, Rotate, Scale & Mirror objects | Andrew1979 | Tutorials & Tips'n'Tricks | 2 | 27th Jul 2009 07:36 am |
| Stretch Wont Stretch | daveyboyd | AutoCAD 2D Drafting, Object Properties & the Interface | 18 | 21st Sep 2008 03:06 am |
| add group | htls69 | Feedback | 4 | 7th May 2008 11:25 am |
| Help: Grouped objects do not appear in GROUP Dialog Box | StykFacE | AutoCAD Drawing Management & Output | 2 | 27th Aug 2007 11:26 pm |
| stretch group to fit to surrounding polygon? | terrordemon | Design Software | 5 | 27th Nov 2006 07:52 pm |
