Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > AutoCAD > AutoLISP, VBA, the CUI & Customisation
Reply
Thread Tools
Old 4th Nov 2009, 08:52 am   #1
xspacex
Full Member
Using: MEP 2008
Default Access Annotation Plot Scale in AutoCAD MEP 2010
I use to be able to access the annotation plot scale in AutoCAD MEP 2008 using lisp from the dictionaries as shown below, but this does not work in AutoCAD MEP 2010. I am hoping that someone knows how I can access the anootation plot scale found under "drawing setup" in MEP 2010? Thanks.
(cdr (assoc 42 (dictsearch (cdr (assoc -1 (dictsearch (namedobjdict) "aec_vars"))) "aec_vars_dwg_setup")))
xspacex is offline   Reply With Quote
Old 5th Nov 2009, 08:40 am   #2
xspacex
Full Member
Using: MEP 2008
I was wondering if somone knows how I can access the "annotation plot size" found under "drawing setup" in AutoCAD MEP 2010 using activex...
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
HELP: AutoCAD 2010 Drawing Scale! tli3 AutoCAD Drawing Management & Output 1 10th Oct 2009 03:55 pm
Is there any differences in Lisp for AutoCAD 2010 muck AutoLISP, VBA, the CUI & Customisation 24 27th Aug 2009 01:12 pm
Running LISP(S) in AutoCAD 2010 CADken AutoCAD General 3 17th Jun 2009 02:25 pm
Lint Type Scale changes when i change annotation scale!! JBullseye74 AutoCAD 2D Drafting, Object Properties & the Interface 4 10th Jun 2009 02:30 pm
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
