#1 |
Senior Member
![]() ![]() ![]() Using: Civil 3D 2007 Join Date: Jul 2009
I have setup my title sheet so that the scale is linked to the viewport scale and plotscale using fields. This is because we plot a lot of our drawings at A3 for reports as well as using them at A1.
My question is can someone do a lisp that would set the page setup (my page setups are simply called A1 and A3) and would then regenall so that the fields get updated. I would appreciate help on this. Thanks. ![]() |
"Some so-called open minds should be closed for repairs."
#2 |
Senior Member
Not to worry, I just got it.
I used this: Code:
(defun c:A3 () (command "-plot" "n" "" "A3" "" "n" "y" "n") (command "regenall") (princ) ) |
#3 |
Full Member
![]() ![]() Using: AutoCAD 2009 Join Date: Oct 2008
Can I ask a couple related questions here?
(1) Using Detailed Plot Configuration.. I want to plot EVERY LAYOUT How do I page through them all? Sometimes I do not plot Model Space but only the Layouts.. (2) I sometimes need to change printers and I'd like to have a routine for this. Problem is they each have Path Names and some have spaces. I don't know how to pass a name such as "\\MyServer\MyPrinter PCL" The names are giving me problems. Renaming is NOT an option (Corporate thingie!) Thanks in advance! You guys are awesome!! Last edited by ILoveMadoka : 4th Nov 2009 at 01:41 pm. Reason: Revise |
| Thread Tools | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Auto LISP routine to assign Page Setup | Ham007 | AutoLISP, VBA, the CUI & Customisation | 7 | 5th Mar 2009 04:56 pm |
| Lisp to import page setup | Grigs | AutoLISP, VBA, the CUI & Customisation | 8 | 4th Feb 2009 03:25 am |
| Page setup | takaki | AutoCAD General | 9 | 26th Oct 2008 07:23 pm |
| Page Setup | nauggie | AutoLISP, VBA, the CUI & Customisation | 2 | 17th Jan 2007 12:05 am |
| Page Setup | Tatu100 | AutoCAD General | 9 | 14th Aug 2006 01:43 pm |
