#1 |
Senior Member
![]() ![]() ![]() Using: AutoCAD 2007 Join Date: Apr 2007
Hi guys!
Im stuck with this boring routine of reading dimension values and typing them in Excel columns for furtegr calculations. My dimenison are alinged in one horizontal line (see picture; blue line represents how would values had to be arranged in Excel). Is there anyway I could select all the dimesnions at once and copy the values in Excel column? You can see the picture attach of what I had in mind. Is something like this possible? Maybe another insanly/impossible great thing would be, selecting hatch and coping its area value to excel. Anyway, if anything of this is possible I would appricate it ![]() ![]() |
#2 |
Super Member
![]() ![]() ![]() ![]() Using: AutoCAD 2008 Join Date: Jul 2005
Quote:
Just change file name Code:
Option Explicit
Sub SortDims()
Dim oSset As AcadSelectionSet
Dim oEnt As AcadEntity
Dim oDim As AcadDimension
Dim oDimAln As AcadDimAligned
Dim oDimRot As AcadDimRotated
Dim eCnt As Integer
Dim iCnt As Integer
Dim rCnt As Integer
Dim iNdx As Integer
Dim insPnt() As Double
Dim fcode(0) As Integer
Dim fdata(0) As Variant
Dim dxfCode, dxfdata
fcode(0) = 0: fdata(0) = "DIMENSION"
dxfCode = fcode
dxfdata = fdata
Set oSset = ThisDrawing.PickfirstSelectionSet
oSset.Clear
oSset.SelectOnScreen dxfCode, dxfdata
iCnt = oSset.Count
ReDim SelPnt(0 To iCnt - 1, 0 To 3) As Variant
eCnt = 0
For Each oEnt In oSset
Set oDim = oEnt
insPnt = oDim.TextPosition
SelPnt(eCnt, 0) = insPnt(0)
SelPnt(eCnt, 1) = insPnt(1)
SelPnt(eCnt, 2) = insPnt(2)
If TypeOf oDim Is AcadDimAligned Then
Set oDimRot = oEnt
SelPnt(eCnt, 3) = oDimRot.Measurement
ElseIf TypeOf oDim Is AcadDimRotated Then
Set oDimRot = oEnt
End If
eCnt = eCnt + 1
Next oEnt
ReDim sortPnt(0 To iCnt - 1, 0 To 3) As Variant
sortPnt = ColSort(SelPnt, 1)
Dim xlApp As Excel.Application
Dim xlBook As Workbook
Dim xlSheet As Worksheet
Dim strFilePath As String
strFilePath = "C:\ExtractDims.xls" '<-- must be exist
On Error Resume Next
Err.Clear
Set xlApp = GetObject(, "Excel.Application")
If Err <> 0 Then
Err.Clear
Set xlApp = CreateObject("Excel.Application")
If Err <> 0 Then
MsgBox "Cannot start Excel", vbExclamation
End
End If
End If
xlApp.Visible = True
On Error GoTo 0
Dim CheckOpen As Boolean
Dim OpenCnt As Long
Dim strFilePath_Name As String
For OpenCnt = 1 To xlApp.Workbooks.Count
If xlApp.Workbooks(OpenCnt).FullName = strFilePath Then
CheckOpen = True
strFilePath_Name = xlApp.Workbooks(OpenCnt).Name
ElseIf CheckOpen = True Then
CheckOpen = True
Else
CheckOpen = False
End If
Next
If CheckOpen Then
Set xlBook = xlApp.Workbooks(strFilePath_Name)
Set xlSheet = xlBook.Worksheets(1)
Else
Set xlBook = xlApp.Workbooks.Open(strFilePath)
End If
Dim irow As Long
irow = 1
With xlSheet
.Range("A:A").NumberFormat = "0.00#"
For iNdx = 0 To UBound(sortPnt, 1)
.Cells(irow, 1) = CStr(sortPnt(iNdx, 3))
irow = irow + 1
Next iNdx
End With
End Sub
' written by Fatty T.O.H. (c)2006 * all rights removed '
' SourceArr - two dimensional array '
' iPos - physical position of item in the sublist (starting from 1) '
Public Function ColSort(SourceArr As Variant, iPos As Integer) As Variant
Dim Check As Boolean
ReDim tmpArr(UBound(SourceArr, 2)) As Variant
Dim iCount As Integer
Dim jCount As Integer
Dim nCount As Integer
iPos = iPos - 1
Check = False
Do Until Check
Check = True
For iCount = LBound(SourceArr, 1) To UBound(SourceArr, 1) - 1
If SourceArr(iCount, iPos) > SourceArr(iCount + 1, iPos) Then
For jCount = LBound(SourceArr, 2) To UBound(SourceArr, 2)
tmpArr(jCount) = SourceArr(iCount, jCount)
SourceArr(iCount, jCount) = SourceArr(iCount + 1, jCount)
SourceArr(iCount + 1, jCount) = tmpArr(jCount)
Check = False
Next
End If
Next
Loop
ColSort = SourceArr
End Function
The soul is healed by being with children. - Fyodor Dostoyevsky, novelist (1821-1881)
#3 |
Senior Member
Fixo, what the hell is that?
How do I activate it, and how to use it? |
#4 | ||
Super Member
Quote:
Quote:
PS This will not work in 2010 version ~'J'~ |
#5 |
Super Member
The same thing on Lisp
Code:
(defun C:dx (/ *error* abks aexc asht col data dim_data elist en i row row_data ss tmp xbks xcel xshs)
(vl-load-com)
(defun *error* (msg)
(if
(vl-position
msg
'("console break"
"Function cancelled"
"quit / exit abort"
(princ "Error!")
(princ msg)
(if (setq ss (ssget (list (cons 0 "dimension"))))
(setq i -1)
(repeat (sslength ss)
(setq en (ssname ss (setq i (1+ i)))
elist (entget en)
tmp (cons (cdr (assoc 11 elist)) (cdr (assoc 42 elist)))
data (cons tmp data))
(setq dim_data (vl-sort data
(function (lambda (e1 e2) (< (caar e1) (caar e2))))))
(alert "Close Excel File Only")
(setq aexc (vlax-get-or-create-object "Excel.Application")
xbks (vlax-get-property aexc "Workbooks")
abks (vlax-invoke-method xbks "Add")
xshs (vlax-get-property abks "Sheets")
asht (vlax-get-property xshs "Item" 1)
xcel (vlax-get-property asht "Cells")
(vla-put-visible aexc :vlax-true)
(setq row 0
col 1)
(repeat (length dim_data)
(setq row_data (car dim_data))
(setq row (1+ row))
(vlax-put-property
xcel
"Item"
row
col
(vl-princ-to-string (cdr row_data))
(setq dim_data (cdr dim_data))
(vlax-invoke-method
abks
'SaveAs
"C:\\ImportDims.xls"
-4143
nil
nil
:vlax-false
:vlax-false
1
2
(vlax-release-object xcel)
(vlax-release-object asht)
(vlax-release-object xshs)
(vlax-release-object abks)
(vlax-release-object xbks)
(vlax-release-object aexc)
(setq aexc nil)
(gc)
(gc)
(*error* nil)
(prompt "\n\t\t>>>\tType DX to execute\t<<<\n")
#6 |
Senior Member
OK!
Ill give it a run and will get back to you :-) Thanx in advance :-) |
#7 |
Senior Member
Fixo its working, but theres a little problem.
eg. the values in acad says 3,14m, when copied to excel it says 313.992 Its a little extra work in Excel no problem, but can the values be the same in Acad and in Excel? Thanx :-) |
#8 | |
Super Member
Quote:
~'J'~ |
#9 |
Senior Member
I saved as 2004 and 2007 .dwg file
p.s. I used the .lsp file |
#10 |
Super Member
It's strange
This lisp works good on my end I have Excel2003 on my machine installed See attachment Check Excel file - perhaps there are some formulas into the cells was embedded Another thought Try to change this line: (vl-princ-to-string (cdr row_data)) on: (rtos (cdr row_data) 2 2) ~'J'~ |
| Thread Tools | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Manipulating dimension values | silverfish | AutoLISP, VBA, the CUI & Customisation | 18 | 1st Jul 2009 03:13 pm |
| saving values to excel and back | comcu | AutoLISP, VBA, the CUI & Customisation | 5 | 29th Apr 2009 09:51 pm |
| Can I insert values of text into Excel table | todorb2000 | AutoLISP, VBA, the CUI & Customisation | 6 | 6th Jan 2009 02:18 pm |
| help!!! export autocad values in excel | disease34 | AutoCAD Drawing Management & Output | 0 | 7th Aug 2006 03:43 pm |
| AutoDraw within AutoCAD from variables/values from Excel | Jedidia | AutoCAD General | 2 | 24th Jun 2005 02:12 pm |
