#1 |
Full Member
![]() ![]() Using: AutoCAD 2009 Join Date: Oct 2008
I asked a question in another thread
http://www.cadtutor.net/forum/showthread.php?t=41644 Since I'm changing topics a bit I thought I better make it a separate thread altogether.. Question 1: I want to plot EVERY LAYOUT in a DWG. I may have 1 I may have 20. How do I page through them all? Let me clarify here, I want to be able to change the printer/page setup on all layouts in a lisp file. Sometimes I do not plot Model Space but only the Layouts.. (2) I sometimes need to change printers and I'd like to have a routine for this. Problem is they each have Path Names and some have spaces. I don't know how to pass a name such as "\\MyServer\MyPrinter PCL" The names are giving me problems. Renaming is NOT an option (Corporate thingie!) Thanks in advance! You guys are awesome!! Last edited by ILoveMadoka : 4th Nov 2009 at 07:42 pm. Reason: typo |
#2 |
Super Member
have you checked out publish? and creating named page setups?
"The problem is stupidity. I am not saying there should be capital punishment for stupidity, but, why don't we just take the safety labels off of everything and let the problem solve itself? "
#3 |
Super Member
![]() ![]() ![]() ![]() Using: AutoCAD 2008 Join Date: Jul 2005
How about "\\\\MyServer\MyPrinter PCL"
four backslashes at front of Not tested ~'J'~ |
The soul is healed by being with children. - Fyodor Dostoyevsky, novelist (1821-1881)
#4 |
Junior Member
![]() Using: AutoCAD 2010 Join Date: Nov 2009
I think publish is the answer. You might want to consider using sheet set too.
#5 |
Full Member
![]() ![]() Using: AutoCAD 2010 Join Date: Oct 2009
Try with thea ttached zip file.
It's an application I write some time ago. It's designed to plot diferent dwg files to dwf files and pdf files. It plots the current paperspace, but it can be modified to plot any number of parperspace layouts and modelspace. It is a perform a "brute force attack" plot... so, be patient Fell free of change it as you want or need. If you have any question let me know. Notice you must install or create a "DWF classic.pc3" file. |
| Thread Tools | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Create a page setup for plotting | AutoCAD Tips Blog | AutoCAD RSS Feeds | 0 | 7th Apr 2009 04:00 am |
| Page setup | takaki | AutoCAD General | 9 | 26th Oct 2008 07:23 pm |
| Slow Plotting / Page Setup Manager | ateewarr | AutoCAD Drawing Management & Output | 2 | 20th Oct 2008 05:58 pm |
| Page Setup | nauggie | AutoLISP, VBA, the CUI & Customisation | 2 | 17th Jan 2007 12:05 am |
| Page Setup | Tatu100 | AutoCAD General | 9 | 14th Aug 2006 01:43 pm |
