Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > AutoCAD > AutoCAD Vertical Products > Civil 3D & LDD
Reply
Thread Tools
Old 4th Nov 2009, 10:09 pm   #1
Cadologist
Full Member
Cadologist's Avatar
Using: Civil 3D 2009
Default Export To ACAD: Text Problem (Masking)
Does anyone know a solution to this problem, when I export a drawing to AutoCAD, any text that was masked in C3D (possibly through a style or however) has the mask overwrite the text, ending up with big soild filled boxes where the text shows (when plotting) through AutoCAD (screen view is fine).
Basically the text mask backgrounds are dominant, ie: draworder doesn't do a single thing and the only way to fix it so far that I know of is to manually go in, delete all the masks, then remask all the text, real PITA when your dealing with extensive networks of alignments (roadway designs).
Any ideas?
Cadologist is offline   Reply With Quote
Old 4th Nov 2009, 10:13 pm   #2
Cadologist
Full Member
Cadologist's Avatar
Just to add, the text masks when converted to AutoCAD are actually 'SOLID HATCH' with the color 0,0,0 on the same layer as the text, which sucks. Draworder doesn't effect it at all, looks good on the screen, prints with the hatch covering the text.
Old 4th Nov 2009, 10:16 pm   #3
Cadologist
Full Member
Cadologist's Avatar
Found some information but still 'sucks'....... see below.
Problem #2: Object Coloring/Text Hatches
When Civil 3D exports labeled contours or certain pipe labels, it creates a hatch behind the text, and colors that hatch whatever your background color is. If your model space is anything but white, the hatch will show up in your plots, often as a filled black rectangle. So you need an quick way to fix that. Again, there are two possible solutions:
Change the hatch to white (255,255,255). You can select everything in your drawing and then select “hatch” from the Properties window drop-down box, then adjust the color from there. If you have other hatches in your drawing, you may want to isolate the layer(s) that the text hatches are on using LAYISO.
You can delete all of the hatches and replace them with background masks. Again, you might want to isolate the relevant layers before doing this. Use the Properties window drop-down to select all MText entities. Once you have selected only MText that you want to mask (using Shift-selections to remove those that you don’t), you can click on the ellipses next to Background Mask and set your mask.
Be sure to set the background color to “use drawing background color”.
Old 5th Nov 2009, 12:26 am   #4
sinc
Full Member
Using: Civil 3D 2010
If you switch to paperspace before doing the export, then the hatches all get dumped out with white backgrounds, which print correctly, as long as you aren't using a "Lines Merge" option in your printer.
sinc is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
plot with text masking JWSLU AutoCAD 2D Drafting, Object Properties & the Interface 2 19th Jun 2009 04:59 pm
Text masking... EMS_0525 AutoCAD 2D Drafting, Object Properties & the Interface 3 20th Mar 2009 03:25 pm
Text masking Scott44 AutoCAD General 3 6th Aug 2008 10:05 am
acad 2009...export layout to model problem... hazardman AutoCAD Drawing Management & Output 2 4th Apr 2008 04:41 pm
text masking Figment AutoLISP, VBA, the CUI & Customisation 4 20th Dec 2007 06:22 pm
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
