Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > AutoCAD > AutoCAD 2D Drafting, Object Properties & the Interface
Reply
Thread Tools
Old 6th Nov 2009, 04:36 pm   #1
lenmac
Junior Member
Using: AutoCAD LT 2000
Default Inserting OLE Objects in AutoCad 2000 LT
I have inserted a spreadsheet into my drawing. When I try to plot to my 11x17 laser printer, the Preview looks great, but the printed copy blacks out the spreadsheet portion. The only way I can get anything to print is to set the OLE Plot Quality to Photograph, and then the text is blurry and nearly illegible. What am I doing wrong?
lenmac is offline   Reply With Quote
Old 6th Nov 2009, 10:41 pm   #2
ReMark
Quantum Mechanic
ReMark's Avatar
Using: AutoCAD 2009
What command did you use to insert the spreadsheet?
Education is a lifelong process.
ReMark is offline   Reply With Quote
Old 7th Nov 2009, 02:29 pm   #3
lenmac
Junior Member
I Copied the spreadsheet selection to the Clipboard in Microsoft Excel, then in AutoCad selected Edit and Paste. I have tried every Plot Quality option and the only one that produces any image is Photograph, and even then it is distorted. All other Plot Quality options produce a blacked-out image.
Old 7th Nov 2009, 02:35 pm   #4
ReMark
Quantum Mechanic
ReMark's Avatar
Using: AutoCAD 2009
There are a couple of options mentioned in this thread found at the AutoDesk Discussion Groups (paste special and dotSoft Tool Pac). Take a look.
http://discussion.autodesk.com/forum...threadID=22021
Old 7th Nov 2009, 07:03 pm   #5
Tankman
Super Member
Tankman's Avatar
Using: AutoCAD 2005
Appears dotSoft Tool Pac would work fine however excluding LT.
I could be wrong but, I'll take a closer look later.
Tankman
"When the well is dry, we know the worth of water." Ben Franklin ~ 1746
Tankman is offline   Reply With Quote
Old 9th Nov 2009, 01:57 pm   #6
lenmac
Junior Member
Remark:
Thanks! in your link, I found the answer I was looking for. Paste Special and choose Autocad Entity - worked great.
Len
Old 9th Nov 2009, 02:01 pm   #7
ReMark
Quantum Mechanic
ReMark's Avatar
Using: AutoCAD 2009
You're welcomed Len. Glad to hear you found a solution to your problem.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Inserting a PDF (CAD 2000) andyboy AutoCAD Drawing Management & Output 4 28th Sep 2006 05:35 am
AutoCAD Lt 2000: OLE objects not viewable in paper space The Bald One AutoCAD Drawing Management & Output 6 7th Apr 2006 01:35 pm
Network problem in AutoCad 2000 + Win 2000 xper_mental AutoCAD Drawing Management & Output 8 24th Jan 2006 04:45 pm
Inserting OLE objects daiharv AutoCAD Drawing Management & Output 1 10th Oct 2005 03:04 pm
Inserting OLE Objects Dan AutoCAD Beginners' Area 1 10th Feb 2003 02:01 pm
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
