Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > AutoCAD > AutoCAD Vertical Products > Civil 3D & LDD
Reply
Thread Tools
Old 6th Nov 2009, 05:13 pm   #1
Martini
Full Member
Martini's Avatar
Using: LDD 2009
Default Questions using Trimble TSC2
Ok I am new to the whole GPS side of surveying. I have a Trimble TSC2 with all of the survey information from one of my job sites on it. It has all of my structures, road elevation, etc. So my question is how to I get the points off of this thing. Its not like any of my other data collectors, and i don't see any export as option. Any help would be greatly appreciated. I feel like an idiot not knowing more about these things.
Thanks
Martini is offline   Reply With Quote
Old 6th Nov 2009, 09:49 pm   #2
Martini
Full Member
Martini's Avatar
Using: LDD 2009
I have connected it to the computer, and synced it and found the txt file but autocad ldd 2009 says "no points transfered from source" when I try to import the txt file that is. Is there a conversion that I need to do or a export method?
Old 7th Nov 2009, 04:07 pm   #3
sinc
Full Member
Using: Civil 3D 2010
Are you using Survey Controller on your TSC2? If so, it doesn't store data in a TXT file. I believe everything is in a JOB file. You can export points to a CSV file, if that's what you are trying to do. That's what we usually do. Our field guys typically dump JOB, DC, and CSV files to the server.
sinc is offline   Reply With Quote
Old 7th Nov 2009, 07:00 pm   #4
alanjt
Super Member
alanjt's Avatar
Using: Civil 3D 2009
In the survey software, on the data collector, find the Export option. From there you should be able to, as sinc said, export to .csv, .txt (some can), etc. Then just transfer it over to your computer and load into LDD. With 09, I don't know if you can in LDD, but in C3D, you have SurveyPro (I think that's the transfer program). With it, you can dump the data collector and convert to pretty much any format.
Seann: ...it went crazy ex-girlfriend on me...
eric_monceaux...
its pretty funny seeing two AutoCAD Gods give each other flak...
alanjt is offline   Reply With Quote
Old 8th Nov 2009, 02:03 am   #5
klyph
Forum Newbie
Do you have Trimble Geomatics Office installed on the computer? That is how we always downloaded points. It is a very useful program to have if you are using Trimble equipment. You just create a new job, or download into an existing one. The interface is very easy to use.
klyph is offline   Reply With Quote
Old 9th Nov 2009, 02:24 pm   #6
Martini
Full Member
Martini's Avatar
Using: LDD 2009
On the collector I have SCS900, and on my computer I have SCS data manager, Office Synchronizer, acugrade office, terramodel. I am not to familiar with this type of data collector but thanks for the help everyone.
Old 9th Nov 2009, 10:56 pm   #7
klyph
Forum Newbie
Ah, when you said Trimble TSC2 I assumed you were running trimble software. I don't know about SCS products, but you should try uploading from the collector to the desktop software, then to LDD. Also, can you post the .txt file you were trying to load? There might just be something wrong with the formatting.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
2 questions! spursnutter AutoCAD 3D Modelling & Rendering 8 2nd Jul 2008 06:13 pm
Got a few questions about UI Drewseph AutoCAD 3D Modelling & Rendering 2 5th Apr 2008 10:25 pm
need questions mariappan AutoCAD Beginners' Area 53 23rd Jan 2008 07:11 am
Several questions ppc AutoCAD 3D Modelling & Rendering 3 25th Jul 2006 01:44 pm
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
