Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > Digital Design > SolidWorks
Reply
Thread Tools
Old 7th Nov 2009, 05:03 am   #1
lulumara
Senior Member
lulumara's Avatar
Version: not specified
Unhappy Opening Solidworks Assembly
Hi I was opening Assembly but keeps looking around or not finding the parts such as bolts and washer and parts in the right folder but as I know I didn't move any parts of the drawing it was only one files or folder?? So I can't even opening it , Do I missed something how to open the files without Solidworks keep on looking where the files is?
Jimmy - using AutoCad 2009 LT and Solidworks 2009
lulumara is offline   Reply With Quote
Old 7th Nov 2009, 05:10 pm   #2
Lazer
Super Moderator
Lazer's Avatar
Using: Inventor 2009
when it is looking for the folder with the bolts and washers are you pointing to the correct folder? if they are in there then I would guess it would insert them into the assembly?
USING AUTOCAD 2009 AND INVENTOR 2009.
If in doubt scale and don't ask!
Lazer is offline   Reply With Quote
Old 8th Nov 2009, 02:22 pm   #3
lulumara
Senior Member
lulumara's Avatar
When I made the assembly , I used the library for the bolts and washer , I just insert it. But when I open the assembly it was looking for the parts(bolts and washer). Then a dialog box open as solidworks should look for the bolts and washer but after clicking ok it will assume with different bolts and washer kinda big though? It does that evertime I open an assembly?
Old 8th Nov 2009, 02:58 pm   #4
shift1313
Super Member
shift1313's Avatar
Using: AutoCAD 2005
Where did it save your hardware in relation to your project? Do you have a folder for hardware?
Matt
SolidWorks09,SolidCam08,Unigraphics NX 5.0,Autocad 05/07/09/10, Inventor Pro 10/11/2009/2010, MasterCamX3, ProE Wildfire 4.0
shift1313 is offline   Reply With Quote
Old 8th Nov 2009, 03:04 pm   #5
lulumara
Senior Member
lulumara's Avatar
I know its on Program files/Solidworks/Toolbox/data
Old 9th Nov 2009, 04:27 pm   #6
lulumara
Senior Member
lulumara's Avatar
Any ideas ? It was on C drive that Solidworks but the actual drawings all of them in D drive?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Thread Hole Misfit Assembly Problem : Intereference in Assembly DaMieN Autodesk Inventor 4 3rd Oct 2009 05:42 pm
E-drawings not opening assembly properly Jrashaw SolidWorks 5 11th Sep 2009 06:46 pm
Solidworks Assembly kieronsmith SolidWorks 1 8th Oct 2008 06:36 pm
Assembly h0wi3 AutoCAD 3D Modelling & Rendering 4 21st Aug 2008 05:20 am
Sub Assembly ankurpraja Autodesk Inventor 2 12th Apr 2008 10:15 pm
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
