Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > AutoCAD > AutoCAD Beginners' Area
Reply
Thread Tools
Old 7th Nov 2009, 11:57 am   #1
luke83
Junior Member
Using: AutoCAD 2008
Wink Draw line on angles
OK I NEED TO DRAW A LINE FROM A POINT THATS TRAVELS 80MM ALONG X AND IT INCREASES WITH A ANGLE OF 5DEGS.
sO HEARS WHAT I DID
L
SELECTED MY STARTING POINT
@80,<5
nOW LOOKING AT IT IT LOOKS FINE TO MY UNTRAINED EYE, BUT HALFWAY THRU DRAWING THIS IMAGE OF A VAN, I REALISED MY SIZES WHERE OUT, NOW I ACTUALLY WANTED TO HAVE MY MEASURMENT OF 80MM ALONG THE X AXES NOT HEADING OFF ALONG THE DIAGONAL IS THERE ANOTHER WAY TO TELL IT THAT I WANT THAT LINE ALONG THAT ANGLE BUT TO TAKE ITS MEASURMENT OFF THE X AXIS ONLY NOT ALONG THE LINE ITS TRAVELLING.
does that make sence?
luke83 is offline   Reply With Quote
Old 7th Nov 2009, 01:40 pm   #2
dbroada
Forum Deity
dbroada's Avatar
Using: Electrical 2008
there probably is but I just put a vertical XLINE through the stating point, move that 80<0 and extend the previous line.
If you need a lot of lines at various angles you can also twist the UCS as you go.
Dave
dbroada is offline   Reply With Quote
Old 7th Nov 2009, 04:26 pm   #3
Tankman
Super Member
Tankman's Avatar
Using: AutoCAD 2005
You would need to do a bit of geometry, develop the triangle.
You could fudge a bit. Take a peek-a-boo at the attached *.dwg file.
You can see drawing an 80 unit line, @80<5 would be .25 units short. Oh, my!
There would certainly be a lot of accumulated errors.
Tankman
"When the well is dry, we know the worth of water." Ben Franklin ~ 1746
Tankman is offline   Reply With Quote
Old 7th Nov 2009, 05:22 pm   #4
Lazer
Super Moderator
Lazer's Avatar
Using: Inventor 2009
Luke you may want to type without caps on as some people regard this as SHOUTING!!
USING AUTOCAD 2009 AND INVENTOR 2009.
If in doubt scale and don't ask!
Lazer is offline   Reply With Quote
Old 7th Nov 2009, 05:37 pm   #5
Cad64
Super Moderator
Cad64's Avatar
Using: AutoCAD 2008
Tankman, you need to remove the "%20" from the name of the file you posted. I couldn't get it to open until I renamed it.
"Work Smart, Not Hard"
My Personal Portfolio ( Updated 10/25/09 ): http://www.rdeweese.com/
Cad64 is offline   Reply With Quote
Old 7th Nov 2009, 06:34 pm   #6
Tankman
Super Member
Tankman's Avatar
Using: AutoCAD 2005
Quote:
Sorry Cad64, this was at first Luke's drawing which I edited.
I never use the % sign naming any drawing.
On my laptop, AutoCAD '05, I couldn't open your drawings, oh, my.
Was 23°F here in Eastern Pennsylvania today. Yuk!
Tankman
Old 7th Nov 2009, 09:27 pm   #7
luke83
Junior Member
Using: AutoCAD 2008
Thanks tankman for the .dwg , thats the way i ended up doing it but wasnt sure if there was another easier way.
Sorry about the SHOUTING people, i didnt reliase capslock was on until the very end and being 11:30 at night when i wrote it i didnt feel like retyping the whole thing.
Old 7th Nov 2009, 11:15 pm   #8
nukecad
Full Member
nukecad's Avatar
Using: AutoCAD LT 2002
XLINE is a good, but it seems, little known command.
You want a 5deg angle, use
XLINE
A (for angle)
5
<enter>
that will put a 5 degree construction line on your drawing.
Other XLINE options are-
H (horizontal)
V (vertical)
O (offset by a distance you specify)
T (tangental to a radius)
etc., take a look at the HELP for all the options.
I'm only here for the beer. (It neutralises the gamma rays).
nukecad is offline   Reply With Quote
Old 8th Nov 2009, 12:59 pm   #9
dbroada
Forum Deity
dbroada's Avatar
Quote:
clearly. I think my solution is easier than the one taken.
Dave
Old 8th Nov 2009, 02:51 pm   #10
Tankman
Super Member
Tankman's Avatar
Using: AutoCAD 2005
Clearly, Dave, your solution is easier. Does down smooth too!
Hope Guy Fawkes day was fun in Sussex!
Tankman
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
lisp to draw line on same angle as line picked john_ AutoLISP, VBA, the CUI & Customisation 12 21st Oct 2009 03:32 pm
How to display angles and line lengths in autocad nils AutoCAD Beginners' Area 13 16th Jul 2008 08:31 pm
A Challenege - Draw Line, Blocks Placed on Line CADken AutoLISP, VBA, the CUI & Customisation 12 5th Feb 2008 03:46 am
Can't draw line suddenly! Help! umop-3p!sdn AutoCAD Beginners' Area 6 14th Jun 2007 08:22 am
I can't draw a line. Gideon AutoCAD 3D Modelling & Rendering 6 30th Mar 2007 04:21 pm
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
