#1 |
Forum Newbie
Using: AutoCAD 2008 Join Date: Nov 2009
Hello guys, I have a series of parallel lines and need to turn them into points all at the same time (more than 1000 lines each file so I can't do it one by one).
I already used a lisp and calculated the total lenght of them all, but when I try to divide, it only allow me to divide one line at a time =//// I also tried to make them into a block and divide the block, but I recieve an error msg. I don't know where I'm messing up ![]() I am not the kind of guy who asks question without doing some research, but I can't find anything about this case on google. ![]() Anyone got some tips for me? Thx in advance. ![]() |
#2 |
Forum Newbie
Sorry, to make it more clear I need to divide them in points of 5m distance each. So I calculated the number of divisions to be made by total lenght. There's also the measure command that I recently learned, but I can't use it on all lines at the same time too.
#3 |
Forum Newbie
I already used a lisp and calculated the total lenght of them all, but when I try to divide, it only allow me to divide one line at a time =//// I also tried to make them into a block and divide the block, but I recieve an error msg. To make it more clear I need to divide them in points of 5m distance each. So I calculated the number of divisions to be made by total lenght. There's also the measure command that I recently learned, but I can't use it on all lines at the same time too. I am not the kind of guy who asks question without doing some research, but I can't find anything about this case on google. ![]() Anyone got some tips for me? Thx in advance. ![]() |
#4 |
Super Member
![]() ![]() ![]() ![]() Using: Civil 3D 2009 Join Date: Apr 2008
You should search the forums.
![]() I knew I had just helped out with something almost identical to this. http://www.cadtutor.net/forum/showth...ghlight=divide Ron and I both posted one here, I'd only suggest mine because I added undo marks, other than that, we wrote the same thing. The only thing you'll need to change is the number sent to divide. Not hard, just add a statement like (setq Num (getint "\nDivide number: ")) then replace the 10 with Num. If you need any further help, just ask, and DON'T post multiple threads in different sections. Your questions will be viewed by everyone; no need to clog up the CT network with the same question. Good luck. ![]() |
Seann: ...it went crazy ex-girlfriend on me...
eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak... |
#5 |
Forum Newbie
Thx alanjt, I'll check that out! Sorry for double post, I regreted posting it on Beginners and didn't know how to delete it. Getting used to the forum.
While I was searching, the tags for this problems resulted in lots and lots of pages with diffrent questions =(( Thx again ![]() |
#6 | |
Super Member
Quote:
No problem. Give a shout if you need help. |
#7 |
Forum Newbie
Alanjt I finally got it!!! Your code reallly helped a lot!! I had lines with diffrent lenghts, so I changed the divide for measure, and adjusted the intervals as I needed, and worked like a gem!
Thx a lot fella!!! ![]() ![]() |
#8 |
Super Member
| Thread Tools | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| creating a surface from lots of points for 3D mapping | sinanp | Rhino | 5 | 13th Feb 2009 12:06 pm |
| New with lots of questions.. | ricracer16 | Hardware & Operating Systems | 14 | 18th Jan 2009 05:15 pm |
| What's the best way to divide 1 line into 2 lines | Almaz | AutoCAD Beginners' Area | 12 | 17th Sep 2007 10:37 pm |
| lots of visitors | Lazer | Autodesk Inventor | 11 | 23rd Jul 2007 01:09 am |
| to divide lines,arc or circle | karagozm | AutoCAD Drawing Management & Output | 7 | 2nd Feb 2007 12:40 pm |
