Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > AutoCAD > AutoCAD Beginners' Area
Reply
Thread Tools
Old 7th Nov 2009, 06:00 pm   #1
Stanier
Full Member
Using: AutoCAD 2000
Default Scaling from full size drawings
Can somebody please help me with the following scaling problem when using Autocad 2000. For example, drawing a line relative to a point I would like to be able to enter as the relative coordinates the values taken from an external drawing multiplied by a suitable scaling factor in order to draw the line and then dimension to my scale size. E.g. I would like to be able to enter as the co-ordinates of the second point of the line the following input: @9*0.0885,0 where 0.0885 is my scaling factor for the X co-ordinate of the line but the system will not accept data. Where am I going wrong?
Many thanks
Stanier is offline   Reply With Quote
Old 7th Nov 2009, 06:03 pm   #2
dbroada
Forum Deity
dbroada's Avatar
Using: Electrical 2008
why are you drawing at a scale? In AutoCAD you should ALWAYS draw full size.
Dave
dbroada is offline   Reply With Quote
Old 7th Nov 2009, 06:29 pm   #3
Stanier
Full Member
Using: AutoCAD 2000
Quote:
Hello Dave - The object is to be able to reproduce a drawing in a model makes scale from data extracted from a full size Works drawing.
Rergards
Old 7th Nov 2009, 07:11 pm   #4
dbroada
Forum Deity
dbroada's Avatar
why not draw it full size and scale once complete.
I think you might be able to use 'cal to launch the command line calculator but I can't be sure.
Dave
Old 7th Nov 2009, 07:25 pm   #5
alanjt
Super Member
alanjt's Avatar
Using: Civil 3D 2009
Yeah, 'cal would be the route to take. I think the only math you can do in the commandline as you are doing is divide, since autocad will just treat it as a fraction and approximate a decimal (or whatever your units are) amount. However, as dbroada said, if you MUST draw at something other than 1:1, just draw the entire thing, then scale. Make life as easy as possible for yourself.
Seann: ...it went crazy ex-girlfriend on me...
eric_monceaux...
its pretty funny seeing two AutoCAD Gods give each other flak...
alanjt is offline   Reply With Quote
Old 8th Nov 2009, 10:48 am   #6
Stanier
Full Member
Using: AutoCAD 2000
Quote:
Hi there - Yes, I now understand that the correct technique is to draw full scale and then apply the scale factor. Thanks to everyone who replied to my query.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Draw twice full size but keep full size dimensions matt4 AutoCAD Beginners' Area 9 19th Apr 2009 03:17 am
Scaling entities per paper size. Johntosh AutoLISP, VBA, the CUI & Customisation 6 22nd Nov 2008 01:00 pm
create and plot full size pdf properly cadfly AutoCAD Drawing Management & Output 12 25th Jan 2008 07:48 pm
Scaling Drawings carl mac AutoCAD Beginners' Area 6 19th Mar 2006 08:58 pm
How to draw Rectangle: Center-Full Base-Full Height? LihtiumOverdosE AutoLISP, VBA, the CUI & Customisation 8 26th Oct 2005 07:00 pm
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
