#1 |
Junior Member
![]() Using: Architecture 2008 Join Date: Nov 2009
Hi there,
First time poster here and was hoping someone could help. I have recently went into my final year of university for building surveying and picked cad for my final year specialization. Our project was to draw a house with auto cad architecture 2008 using all the tools that it has to over. Everything started off quite well until i loaded it up one day and started to draw a wall from the tools palate which was CMU- 190 Rigid-038 air-050 brick-090 Furring. Unlike all my other walls from the plan view where you could see the detailing for the block, brick, insulation etc on the wall it doesn’t show up on plan view like that when i draw it anymore but when i look in 3d wireframe it still looks ok but on the plan it does not. Anyone had a similar problem that could help me Cheers Robert |
#2 |
Full Member
![]() ![]() Using: Architecture 2009 Join Date: Apr 2009
Have you checked your display representation? Sounds to me like you had it on something like medium detail and now it's on presentation.
#3 |
Junior Member
Its on medium detail as well ive compared everying between the two and cannot find the diffrence. I really dont know whats up with it. Its like a line wall with no hatching what so ever where as the other shows the hatching.
#4 |
Full Member
Interesting....I assume you've checked that the walls are the same height and at the same elevation too?
#5 |
Super Member
![]() ![]() ![]() ![]() Using: Architecture 2009 Join Date: Aug 2007
did you go into the materials properties and check that the plan display was turned on? You will also find this within the wall style itself too.
as well in the lower right of the screen, there is a button to turn surface hatch on and off, that may have been inadvertently set to off for plan view. |
#6 | |
Junior Member
Quote:
I find it strange that one part can show detail and another part cannot. Knowing my luck im over looking something 'stupid' and its a simple fix. If you click object viewer to the pan area shows the detail where as the model space does not. Last edited by bertsquall : 8th Nov 2009 at 11:05 pm. Reason: Added more Detail |
#7 |
Full Member
Does it only happen when you bring in a new wall from your palette? Or does it also happen if you copy the wall or do an "add selected" command?
#8 |
Super Member
Select one of the effected walls, right click and then choose "object display" See if any of these are checked, if so then you have an object over ride on that particular wall. What you will need to do is go into the display rep and fix the hatch, or uncheck the boxes to remove all over rides to that particular object, then rinse and repeat for each effected wall.
#9 | |
Junior Member
Quote:
I have done several things to such as:
Sorry for all the bother here. Robert |
#10 | |
Super Member
Quote:
![]() Is there any way you might be able to attach a sample file with a wall displaying the problem you are having? You will need 10 posts total in the help part of the forum before the site will allow attachments, but it would go a long way to helping you solve your problem. |
| Thread Tools | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Linear diameter on detail view | Enfiel3D | Autodesk Inventor | 2 | 21st May 2009 05:16 pm |
| Detail View? | tonika | AutoCAD Beginners' Area | 1 | 30th Apr 2009 05:58 pm |
| Detail instead of Icon view... | Flores | AutoCAD Drawing Management & Output | 12 | 30th Jul 2008 11:56 am |
| Detail view | clappr | AutoCAD General | 7 | 8th Jul 2006 09:15 pm |
| where can i find furniture plan and/or detail 2d? | rami | AutoCAD Drawing Management & Output | 2 | 20th Oct 2005 04:16 pm |
