Hi!!! I have a problem... my crosshair cursor is different. how can I put it back to normal?
Holy giant screen shot Batman!!
Check your cursorsize variable (not going to be it though). Looks like a resolution issue.
sorry the screenshot. in the model the crosshair is like that, but in another layout it's normal, or in another drawing. can explain how I make it go to normal. I'm not very experied in autocad.
sorry my english. I'm portuguese
Hmm, forget what I said....3DOrbit? Not sure.
Psh! You think you have it bad, I'm American. :wink:
I can't solve it =/
any more ideas?
I have AUTOCAD LT 2009
Could you be looking at model space in a 3D view or with a custom UCS?
Sometimes if you hold Shift while you're using the scroll wheel, it will try to rotate your view in 3D. Try View > 3D Views and see if you're looking at a different coordinate plane (you probably want "Top").
If not, try typing "UCS" and then changing to "World"
It is solved. It was the 3d views. Thank you all for everything
