Lee Mac Posted November 26, 2009 Share Posted November 26, 2009 (edited) TabSort Version 2.2 This program will allow the user to manipulate the layout tabs in a drawing with ease, the program controls are detailed below: Program Controls: Top: Move selected Tabs to the top of the list. Up: Move selected Tabs up one notch in the list. Down: Move selected Tabs down one notch in the list. Bottom: Move selected Tabs to the bottom of the list. Sort: Opens the Sort Dialog: Alphabetical: Sort Tabs alphabetically: Hence ~ ("A23" "C22" "B3" "E7") Becomes ~ ("A23" "B3" "C22" "E7") Numerical: Sort Tabs numerically: Hence ~ ("A23" "C22" "B3" "E7") Becomes ~ ("B3" "E7" "C22" "A23") Architectural: Use an Architectural Sorting Method: Hence ~ ("A-1A" "B-3" "A-10C" "B-1.2" "B-1") Becomes ~ ("A-1A" "A-10C" "B-1" "B-1.2" "B-3") Reverse: Reverse the Tab order of Selected Tabs. Pref/Suff: Opens the Prefix/Suffix Dialog to allow the user to add a Prefix and/or Suffix to selected/all Tabs. Add: Add a new layout Tab. Delete: Deletes selected Tabs. Copy: Copies the selected Tabs. Current: Makes the selected Tab the Current Tab. Find: Allows the user to perform a Find & Replace: Done: Finished sorting Tabs, will implement sorting. Reset: Will reset Tab names and Tab order ~ will not reset deleted/added Tabs. Screenshot: Function Syntax: TabSort ;;--------------------=={ TabSort.lsp }==---------------------;; ;; ;; ;; A program designed with the intention to aid in the ;; ;; organisation of layout tabs in a drawing. ;; ;; ;; ;; The program enables the user to organise each layout tab ;; ;; using buttons to move the tabs up, down, to the top, and ;; ;; to the bottom of a list. ;; ;; ;; ;; The user may rename any layout by double clicking on it, ;; ;; and can also add a Prefix and/or Suffix to selected/every ;; ;; layout tab. ;; ;; ;; ;; The program offers the facility to add and delete a ;; ;; layout tab, and also sort the tabs alphabetically, ;; ;; numerically, architecturally; or reverse the order in ;; ;; which they appear. ;; ;; ;; ;; A Find and Replace function is incorporated to allow the ;; ;; user to quickly replace a text string in multiple tabs. ;; ;; ;; ;; The user can also Copy a layout tab, and set the Selected ;; ;; layout tab as the current tab. ;; ;; ;; ;; The Help Dialog can be access by pressing "H" at the Main ;; ;; Dialog. ;; ;; ;; ;;------------------------------------------------------------;; ;; ;; ;; FUNCTION SYNTAX: TABSORT ;; ;; ;; ;; Notes:- ;; ;; The Reset button will reset Tab Order and Tab Names, but ;; ;; will not affect newly created tabs and will not recreate ;; ;; deleted tabs. ;; ;; ;; ;; In the case that multiple tabs are selected, the Current ;; ;; button will set the tab with the lowest index (highest in ;; ;; the list) as the current tab. ;; ;; ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; ;; ;; With Thanks To: ;; ;; -------------------- ;; ;; Gilles Chanteau (Gile) ;; ;; ;; ;; For his fantastic contribution to the list manipulation ;; ;; required for multiple DCL selections, and effort towards ;; ;; the Architectural Sort functions. ;; ;; ;; ;;------------------------------------------------------------;; ;; Charles Alan Butler (CAB) ;; ;; ;; ;; For his excellent idea to incorporate the Help button for ;; ;; those who need it. ;; ;; ;; ;;------------------------------------------------------------;; ;; Version: ;; ;; ;; ;; 1.0 - 13th September 2009 ;; ;; ;; ;; First Release ;; ;;------------------------------------------------------------;; ;; 1.1 - 14th September 2009 ;; ;; ;; ;; Added Mnemonics to Tiles ;; ;; Added text to notify of double-click availability ;; ;; Added option to only pref/suff selected tab ;; ;;------------------------------------------------------------;; ;; 1.2 - 15th September 2009 ;; ;; ;; ;; Added Numerical Sort ;; ;; General Bug Fixes ;; ;;------------------------------------------------------------;; ;; 1.3 - 15th September 2009 ;; ;; ;; ;; Multi-tab Selection Functionality ;; ;;------------------------------------------------------------;; ;; 1.4 - 16th September 2009 ;; ;; ;; ;; Added Button to Set Current Tab ;; ;; Added Copy Tab Functionality ;; ;;------------------------------------------------------------;; ;; 1.5 - 17th September 2009 ;; ;; ;; ;; Fixed Bug to Copy Layout Plot Settings ;; ;;------------------------------------------------------------;; ;; 1.6 - 18th September 2009 ;; ;; ;; ;; Modified Action_Tile Stmts ~ Thanks VovKa ;; ;; Added Architectural Sort Button ;; ;;------------------------------------------------------------;; ;; 1.6.1 - 19th September 2009 ;; ;; ;; ;; Fixed Bugs ~ Thanks for feedback CAB ;; ;;------------------------------------------------------------;; ;; 1.7 - 20th September 2009 ;; ;; ;; ;; Added Find & Replace Functionality ;; ;; Organised buttons/Added Sort Dialog ;; ;;------------------------------------------------------------;; ;; 1.7.1 - 20th September 2009 ;; ;; ;; ;; Replaced StrBrk sub with SplitStr (Gile) ;; ;;------------------------------------------------------------;; ;; 1.8 - 21st September 2009 ;; ;; ;; ;; Added hidden Help Button (CAB) ;; ;; Added Help Dialog Definition ;; ;;------------------------------------------------------------;; ;; 1.8.1 - 22nd September 2009 ;; ;; ;; ;; General Bug Fixes ;; ;;------------------------------------------------------------;; ;; 1.8.2 - 23rd September 2009 ;; ;; ;; ;; Fixed Bug causing crash when Deleting all ;; ;; Tabs ~ thanks VovKa ;; ;;------------------------------------------------------------;; ;; 1.9 - 2nd October 2009 ;; ;; ;; ;; Modified Reverse function to only apply to selected Tabs. ;; ;; Altered Help Dialog to ok_only button ;; ;;------------------------------------------------------------;; ;; 2.0 - 22nd July 2010 ;; ;; ;; ;; Fixed Bug with Find/Replace. ;; ;;------------------------------------------------------------;; ;; 2.1 - 9th December 2010 ;; ;; ;; ;; Fixed Bug with Double Reversal ;; ;;------------------------------------------------------------;; ;; 2.2 - 16th May 2011 ;; ;; ;; ;; Program completely rewritten to update formatting. ;; ;; Upgraded Find & Replace engine to allow for ;; ;; self-referencing find and replace terms and improved ;; ;; visual feedback. ;; ;; Updated list manipulation subfunctions. ;; ;;------------------------------------------------------------;; For instructions on how to run the program see here. Any comments, criticism and suggestions are welcome. Either PM me directly, or reply to the original thread. Enjoy, Lee Code available here. Edited May 17, 2011 by Lee Mac Quote Link to comment Share on other sites More sharing options...
