shooter1 Posted January 25, 2010 Posted January 25, 2010 I am attempting to publish several layouts into one single PDF. All layouts have the plotter set to Adobe PDF and when I publish it appears to work fine. Once it plots the first page it asks for a location to save the PDF to. I specify a location and then the plot process continues with the remaining layouts. However when it is finished and I open the new PDF file it only shows the first page. I am running Autocad Civil 3d 2009 Quote
Tiger Posted January 25, 2010 Posted January 25, 2010 You are using the PUblish command? And you have all the layouts listed in the dialogue? Quote
shooter1 Posted January 25, 2010 Author Posted January 25, 2010 Yes, all the layouts are in the dialogue. When I tab off the plot in background tab and watch the process actually occur on my screen it appears that the other pages are written. I just can't find them as they are not part of the file I specified. Quote
chulse Posted January 25, 2010 Posted January 25, 2010 I had the same problems with Adobe. We switched to Cute PDF - all's well now. Quote
shooter1 Posted January 25, 2010 Author Posted January 25, 2010 After playing with things for a while I found the problem. I need to use the DWG to PDF plotter instead of the Adobe PDF plotter. Quote
chulse Posted January 25, 2010 Posted January 25, 2010 I've had problems with DWG to PDF also, I'd recommend you test well. BTW- CutePDF is free... There are others also. Quote
