Vinnygunn Posted February 9, 2010 Posted February 9, 2010 I need some good ol fashioned noob help guys. i decided to use my teacher's template for an assignment. probably a bad move... but in any case, the layout view is conveniently made as our title block with a viewport where the drawing goes. I'm having trouble scaling the viewport... not because i dont know how, but i cant seem to find the bloody thing. i see the object i drew in model space fine (other than the fact that the scale is too big) but i cant find the viewport border itself to adjust any of the properties. Do you know of any way to call up a viewport? or if theres a way i can at least draw over it or something to recreate my own? I know i can just make my own new layout which i will do if i cant simply find it. attached is the template if it helps. thanks in advance for any help Vince Template_-_Manual_Drafting_-_MECH313-V23.dwg Quote
Vinnygunn Posted February 9, 2010 Author Posted February 9, 2010 btw im referring to layout 1... the viewport in layout 2 is not giving me that problem. Is there just not a viewport but something else similar in layout 1? Edit: i kind of figured out a way to select it with ctrl + a.. what a mess. Quote
Cad64 Posted February 9, 2010 Posted February 9, 2010 The viewport is on a layer called Construction, which is turned off. Just turn it on and you will be able to select it and change the scale. Quote
Vinnygunn Posted February 9, 2010 Author Posted February 9, 2010 ahhhh.. that would explain that. i feel silly now. thanks for your help! cheers Quote
