beproj Posted March 23, 2006 Posted March 23, 2006 Using autocad 2002, anyone knowing how to extract the control points of a spline drawn and writing into a file using autolisp? Thanks! Adit Quote
fuccaro Posted March 24, 2006 Posted March 24, 2006 Test this: (defun c:test() (setq el (entget (car (entsel)))) (setq file (open (getfiled "Output file" "" "" 5) "w")) (repeat (setq i (length el)) (if (= (car (setq l1 (nth (setq i (1- i)) el))) 10) (write-line (strcat (rtos (cadr l1)) "," (rtos (caddr l1))) file) ) ) (close file) ) Quote
beproj Posted March 26, 2006 Author Posted March 26, 2006 Thanks for the code, really hepled a lot!! Adit Quote
fuccaro Posted December 24, 2011 Posted December 24, 2011 Due to some recent interest, here is the code cleaned: (defun c:test() (setq el (entget (car (entsel)))) (setq file (open (getfiled "Output file" "" "" 5) "w")) (repeat (setq i (length el)) (if (= (car (setq l1 (nth (setq i (1- i)) el))) 10) (write-line (strcat (rtos (cadr l1)) "," (rtos (caddr l1))) file) ) ) (close file) ) Quote
