godofcad Posted May 19, 2012 Posted May 19, 2012 Hi, i want to split Words(coma included) from list and create variable for each splitted words Example: "1,221866.070,1937463.651,611.892,A1" want to split like this "1" "221866.070" "1937463.651" "611.892" "A1" waiting for your replies .... :(:(:( Ganesh Shetty Quote
pBe Posted May 19, 2012 Posted May 19, 2012 (edited) Godofcad. splitting the "words" is simple. Are the number of "words" always 5 such as this case? if not. thats where the problem will start, What will be the variable name? diffrent everytime? sample (defun _delFinder (str md / d l str) (while (setq d (vl-string-position md str nil T)) (setq l (cons (substr str (+ 2 d)) l) str (substr str 1 d))) (cons str l) ) (setq str "1,221866.070,1937463.651,611.892,A1") (setq tovar (_delfinder str 44) cnt 0) (foreach words tovar (set (read (strcat "[b][color=blue]Var[/color][/b]" (itoa (setq cnt (1+ cnt))))) words)) var1 -> "1" var2 -> "221866.070" var3 -> "1937463.651" var4 -> "611.892" var5 -> "A1" You can however make do without the variable names and do your thing straight off the list. Edited May 19, 2012 by pBe Quote
pBe Posted May 19, 2012 Posted May 19, 2012 We can take this one step further by assigning the true value of the the collected/splitted "words" (foreach words tovar (set (read (strcat "Var" (itoa (setq cnt (1+ cnt))))) [b][color=blue](if (numberp (setq num (read words))) num words))[/color][/b]) var1 -> 1 (type var1) INT var2 -> 221866.070 (type var2) REAL var3 -> 1937463.651 (type var3) REAL var4 -> 611.892 (type var4) REAL var5 -> "A1" (type var5) STR HTH Quote
Tharwat Posted May 19, 2012 Posted May 19, 2012 Hi . A little bit late to the party , but better than nothing (defun _StepThrough (lst / integer position values variables) ;;; Tharwat 19. May. 2012 ;;; ;;; divide a list that contains commas within ;;; (setq lst (strcat lst ",") integer 0 ) (while (setq position (vl-string-search "," lst 0)) (if (setq values (cons (set (read (strcat "a" (itoa (setq integer (1+ integer)))) ) (substr lst 1 position) ) values ) ) (setq variables (cons (strcat "a" (itoa integer)) variables)) ) (setq lst (substr lst (+ position 2) (strlen lst))) ) (print (reverse variables)) (print (reverse values)) (princ) ) Example of usage ... (_StepThrough "1,221866.070,1937463.651,611.892,A1") Quote
Tharwat Posted May 19, 2012 Posted May 19, 2012 A little bit better .... (defun _StepThrough (lst / chars integer position values variables) ;;; Tharwat 19. May. 2012 ;;; ;;; divide a list of strings that contain commas within ;;; (if (eq (type lst) 'STR) (setq chars (vl-string->list lst))) (if (eq (car chars) 44) (setq lst (substr lst 2 (strlen lst)))) (if (eq (last chars) 44) (setq lst (substr lst 1 (1- (strlen lst))))) (setq lst (strcat lst ",") integer 0) (while (setq position (vl-string-search "," lst 0)) (if (setq values (cons (set (read (strcat "a" (itoa (setq integer (1+ integer))))) (substr lst 1 position) ) values ) ) (setq variables (cons (strcat "a" (itoa integer)) variables)) ) (setq lst (substr lst (+ position 2) (strlen lst))) ) (print (reverse variables)) (print (reverse values)) (princ) ) Quote
ReMark Posted May 19, 2012 Posted May 19, 2012 I just noticed the OP's screen name: God of CAD. One would think the God of CAD would know all the answers. Quote
pBe Posted May 19, 2012 Posted May 19, 2012 (edited) I just noticed the OP's screen name: God of CAD. One would think the God of CAD would know all the answers. Well it could also be an anagram for cadd goof ,take no offence godofcad, we're just "goofing" around Anyhoo. it appears that the "words" are label\coordinates\description for a survey point. Then like i sugested before, go ahead and write (my guess is attributes) the values directly off the list and that will eliminate the need to assign each value to a variable (foreach words (_delfinder str 44) ........ ;<-- your code here ) HTH Edited May 19, 2012 by pBe Quote
godofcad Posted May 19, 2012 Author Posted May 19, 2012 Well it could also be an anagram for cadd goof ,take no offence godofcad, we're just "goofing" around Anyhoo. it appears that the "words" are label\coordinates\description for a survey point. Then like i sugested before, go ahead and write (my guess is attributes) the values directly off the list and that will eliminate the need to assign each value to a variable (foreach words (_delfinder str 44) ........ ;<-- your code here ) HTH Yeah ! exactly Right they are Survey Points ...i just want to import all survey points to cad .... anyhw tanx for codes ..... Tank u pBe and Tharwat ...you guys are awesome........... Quote
pBe Posted May 19, 2012 Posted May 19, 2012 Glad it helps. Holler if you need help inserting the block abd assigning the values. Quote
Blackfish Posted May 19, 2012 Posted May 19, 2012 I just noticed the OP's screen name: God of CAD. One would think the God of CAD would know all the answers. And 'LISP' as an avatar!!! Quote
Tharwat Posted May 19, 2012 Posted May 19, 2012 Yeah ! exactly Right they are Survey Points ...i just want to import all survey points to cad .... anyhw tanx for codes ..... Tank u pBe and Tharwat ...you guys are awesome........... You're welcome . If you are going to import points to cad , I should confess that pBe's code is faster and shorter without a doubt , while my code gives the same result but slower due to few extra checks before giving the needed result . Best of luck. Tharwat Quote
godofcad Posted May 20, 2012 Author Posted May 20, 2012 You're welcome . If you are going to import points to cad , I should confess that pBe's code is faster and shorter without a doubt , while my code gives the same result but slower due to few extra checks before giving the needed result . Best of luck. Tharwat Here is my codes (csv to cad) Here i used Pbe's Codes to split word --------------------------------------------------------------------- (defun Splitter (str md / d l str) (while (setq d (vl-string-position md str nil T)) (setq l (cons (substr str (+ 2 d)) l) str (substr str 1 d))) (cons str l) ) --------------------------------------------------------------------- (defun c:csv_import (/ snp lay file opn rd point est lvl north base_pt sno_pt rmrk_pt sno code ) (setq snp(getvar "osmode")) (setq lay(getvar "clayer")) (setvar "cmdecho" 0) (setvar "osmode" 0) (command "_.UNDO" "G") ------------------------------------------------------------------- (command "_.LAYER" "M" "Serial_No" "c" "1" "" "") (command "_.LAYER" "M" "Level" "c" "2" "" "") (command "_.LAYER" "M" "Remark" "c" "3" "" "") (command "_.LAYER" "M" "Point" "c" "4" "" "") ------------------------------------------------------------------- (setq file(getfiled "Select File To Import" "" "csv" 4)) (setq opn(open file "r")) (while (setq rd(read-line opn)) (setq str rd) (setq Point (Splitter str 44)) ----------------------------------------------------------------- (setq Est(atof(nth 1 point))) (setq north(atof (nth 2 point))) (setq Lvl(atof (nth 3 point))) (setq base_pt (list est north lvl)) ----------------------------------------------------------------- (setq sno_pt(list est (+ north 0.7) lvl)) (setq rmrk_pt(list est (- north 0.7) lvl)) (setq sno(nth 0 point)) (setq Code(nth 4 point)) (command "TEXT" "J" "MC" sno_pt "0.5" "0" sno) (Command "Change" (entlast) "" "p" "la" "Serial_No" "c" "bylayer" "") (command "TEXT" "J" "MC" rmrk_pt "0.5" "0" code) (Command "Change" (entlast) "" "p" "la" "Remark" "c" "bylayer" "") (command "TEXT" "J" "MC" Base_pt "0.5" "0" (rtos lvl)) (Command "Change" (entlast) "" "p" "la" "Level" "c" "bylayer" "") (command "point" base_pt) (Command "Change" (entlast) "" "p" "la" "Point" "c" "bylayer" "") );while (command "pdmode" 35) (command "pdsize" 0.5) (setvar "cmdecho" 1) (setvar "osmode" snp) (setvar "clayer" lay) (command "_.UNDO" "E") (command "Zoom" "e") (princ) );end defun and i am really sorry for i mentioned my cp name as godofcad and my avtar is lisp ...sorry to other guys i am closing my account today :( Quote
Tharwat Posted May 20, 2012 Posted May 20, 2012 You can improve your codes by replacing the command calls with function entmake(x) for layers , texts and points . Quote
pBe Posted May 20, 2012 Posted May 20, 2012 and i am really sorry for i mentioned my cp name as godofcad and my avtar is lisp ...sorry to other guys i am closing my account today :( Why would you do that? I said it before. take no offence, Members are just being silly thats all All work and no play makes godofcad a dull boy.... Quote
godofcad Posted May 20, 2012 Author Posted May 20, 2012 Why would you do that? I said it before. take no offence, Members are just being silly thats all All work and no play makes godofcad a dull boy.... Tank u pBe ...hmm.....Tats ok .... I will Not Feel Bad and Not Closing My Account Tanks for your support :):):):) Quote
pBe Posted May 20, 2012 Posted May 20, 2012 Tank u pBe.. Tanks for your support All the time. keep on coding Quote
Qonfire Posted May 20, 2012 Posted May 20, 2012 Wow first time ever i'm trying help (maybe because i thing i have something to help with, but i admit asking is much more fun. (defun LM:str->lst ( str del / pos ) (if (setq pos (vl-string-search " " str)) (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) I had a similar problem, and i think this thing helped me.it could be modified for criteria of dividing string, i don't remeber details. I'm sorry that i dont remember where i aqcuired this to. Quote
pBe Posted May 20, 2012 Posted May 20, 2012 First of all (setq pos (vl-string-search [b][color=blue]del [/color][/b]str)) and here's a hint [b][color=blue]LM[/color][/b]:str->lst Quote
