DannyH Posted June 19, 2013 Posted June 19, 2013 I'm using ACADlt 2014. When I'm doing a command like offset and want to change the amount of the offset, I usually double right click to get me to a command that I can put in a new distance. The problem is when I do a quick double click it has a pause and will not do the second click. If I wait and take a couple of seconds between clicks, it works fine. I have my "right click customization" turned off. Is there a setting that I can turn down the pause or get rid of it? Thanks Dan Quote
Dadgad Posted June 19, 2013 Posted June 19, 2013 Welcome to CADTutor forum. I am a great believer in TIME SENSITIVE RIGHT CLICK which you no doubt have noticed in the RIGHT CLICK CUSTOMIZATION dialog. You can customize the amount of time required (duration) to differentiate an ENTER click from a SHORTCUT MENU click. Quote
tmelancon Posted July 4, 2013 Posted July 4, 2013 Were you able to figure it out? I hope so. Let us know. Quote
