Honda Matt Posted June 19, 2013 Posted June 19, 2013 We draw with our tick on the dimensions filled in. I have one file that shows them not filled in, in model space but filled in, in paper space. They seem to be printing correctly. What did i turn off/on and how do I fix this? Thanks Matt Quote
tzframpton Posted June 19, 2013 Posted June 19, 2013 A couple things could be causing this. 1. Visual Style 2. FILLMODE Check those two things first and see if that corrects the issue. Quote
Dadgad Posted June 19, 2013 Posted June 19, 2013 Check the UCS in modelspace. I suspect that if you set it to world they will fill in. That or switch to TOP view or PLAN. Quote
Honda Matt Posted June 20, 2013 Author Posted June 20, 2013 Not sure way that changed or what I did but it is fixed now. Thanks for the help. Matt Check the UCS in modelspace.I suspect that if you set it to world they will fill in. That or switch to TOP view or PLAN. Quote
Dadgad Posted June 20, 2013 Posted June 20, 2013 Not sure way that changed or what I did but it is fixed now. Thanks for the help. Matt 2D Solids only display filled when observed from a perspective which is perpendicular to the plane upon which they were created. Once you said that they were printing fine, it had to be your UCS. Happy to help. Quote
