Specify a path to create toolbar(*.mnu)
This code can automatically create the toolbar(*.mnu)
But creating at " my documents ",Can I choose the path?
For example: E:\Program Files\AutoCAD 2010\Support
;;Automatically create the toolbar
(defun create_toolbar (/ file lst x)
 (setvar "cmdecho" 0)
 (vl-load-com)
 (if (not (menugroup "TEMPTOOLBAR"))
     (alert "\nCreating\"TEMPTOOLBAR\"toolbar,Please wait!")
     (setq file (open "TEMPTOOLBAR.mnu" "W"))
     (foreach x '("***MENUGROUP=TEMPTOOLBAR\n\n***TOOLBARS\n**TEMPTOOLBAR"
 "ID_ZCT001   [_Toolbar(\"Block tools\", _Floating, _Hide, 10, 340, 1)]"
 "ID_ZCT011   [_Button(\"Building block\", \"RCDATA_16_OSNEND\", \"RCDATA_16_OSNEND\")]^C^Czline"
 "ID_ZCT012   [_Button(\"Delete block\", \"RCDATA_16_DIMOBL\", \"RCDATA_16_DIMOBL\")]^C^Czdim"
 "ID_ZCT013   [_Button(\"Preview block\", \"RCDATA_16_TEXEDI\", \"RCDATA_16_TEXEDI\")]^C^Cztext"
 "ID_ZCT014   [_Button(\"Rotating block\", \"RCDATA_16_DIMOVE\", \"RCDATA_16_DIMOVE\")]^C^Czch"
(princ (strcat x "\n") file)
     (close file)
     (command "menuload" "TEMPTOOLBAR.mnu")
 (command "TOOLBAR" "Block tools" "S")
(create_toolbar)
 (vl-load-com)
     (setq file (open[b] [color=red][u]"TEMPTOOLBAR.mnu"[/u][/color][/b] "W"))
Try adding the full path there instead of just the filename.
Something like...replace this line with..
(setq file (open[b] [color=red][u]"[/u][/color][/b]E:\\Program Files\\AutoCAD 2010\\Support\\[b][u][color=#ff0000]TEMPTOOLBAR.mnu"[/color][/u][/b] "W"))
and make sure you move the file from my documents to that support folder first ^.^
OK! Thank you !Brandon.
look into
(strcat (getvar 'ROAMABLEROOTPREFIX) "Support\\TEMPTOOLBAR.mnu")
or even
(strcat (vl-filename-directory (findfile "acad.lin")) "\\TEMPTOOLBAR.mnu")
look into
or even
Thank you ,pbe, nice! Automatically determine the CAD installation path.
You are very welcome, did these replies take care of the issue for you?
