Lisp to add polyline then select it to run more command
Hi,
I have a lisp taken from several forums and stiched it together, what it does is it would select a polyline, then offset it with multiple lines and deletes the selected polyline. Now, how do I make this to add the polyline first, then select it to run the offset command..thanks
(defun C:3off()
(setq off1 1.5)
(setq off2 6)
(setq off3 12)
(while (setq obj (car (entsel "\nSelect object:")))
(setq ps (getpoint "\nSide to offset:"))
(if ps
(command "-layer" "set" "0" "")
(command "_offset" "Layer" "Current" "" "")
(command "_offset" off1 obj ps "")
(command "-layer" "set" "RED_LAYER" "")
(command "_offset" off2 obj ps "")
(command "-layer" "set" "MAGENTA_LAYER" "")
(command "_offset" off3 obj ps "")
(command "erase" obj "")
found the answer, I added the following command before the nselect line :
(command "pline"(while (> (getvar 'cmdactive) 0) (command pause)))
The lisp now makes me draw the pline, then select it and point what side the offset will be, it offsets 3 lines with different offset values and also changes the layer and then deletes the polyline I drew.... cool!
