Hello,guys
I Want add more information to make QRCODE. I've done a little bit of searching for this, but have not found what I've needed.
This is a DEMO
(defun c:tt()
 (setq        str
        "1111111011101101001111111-1000001011100101001000001-1011101010110110001011101-1011101011010011001011101-1011101000000110101011101-1000001010011101101000001-1111111010101010101111111-0000000001001100000000000-1100111000010011000101111-0111110111101100101001110-1001101000011010010101011-0101010110110111001111001-1101111100101100110100111-1111010100000001001111110-0000011111000000101000101-0000000111001100111000001-1110101100010011111110001-0000000011101100100011101-1111111000111111101010101-1000001010010110100011001-1011101011101011111110111-1011101001100001110110111-1011101001100011010111110-1000001010101011001101010-1111111011111111110011111"
 (setq pt0 (getpoint "\nSpecify base point:"))
 (setq pt0 (polar (polar pt0 (/ pi 2) 0.5) pi 1.0))
 (setq str0 str
ls1 nil
 (while (wcmatch str0 "*-*")
   (setq n (vl-string-search "-" str0)
  ls1 (cons (substr str0 1 n) ls1)
  str0(substr str0 (+ 2 n))
 (setq ls1 (reverse (cons str0 ls1))
ls1 (mapcar 'vl-string->list ls1))
 (mapcar
   '(lambda(y)
      (setq pt1 (polar pt0 (/ pi -2) 1.0)
     pt0 pt1
      (mapcar
 '(lambda(x)
    (setq pt1 (polar pt1 0.0 1.0))
    (if (= x 49)
      (mkpl pt1)
 y
   ls1
(defun mkpl(pt)
 (entmake (list '(0 . "lwpolyline")
  '(100 . "AcDbEntity")
  '(100 . "AcDbPolyline")
  '(90 . 2)
  '(43 . 1.0)
  (cons 10 pt)
  (cons 10 (polar pt 0.0 1.0))
But can only make a fixed information . I want Enter more information,
like this:
Enter information: xxxxxxx , [Next/ Done] , N (Enter the next one)
Enter information: xxxxxxx [Next/Done] , D (Finish)
I found some …… maybe can help .
http://www.theswamp.org/index.php?topic=44091.msg493463#msg493463
Lee's function ,Thanks.
(defun int2hex ( n )
   (cond
       (   (< n 10) (chr (+ n 48)))
       (   (< n 16) (chr (+ n 55)))
       (   (strcat (int2hex (/ n 16)) (int2hex (rem n 16))))
(defun str->url ( s )
   (apply 'strcat
       (mapcar
           (function
               (lambda ( a )
                   (cond
                       (   (or (<= 65 a 90) (<= 97 a 122) (member a '(45 46 95 126))) (chr a))
                       (   (= a 32) "+")
                       (   (< a 16) (strcat "%0" (int2hex a)))
                       (   (strcat "%" (int2hex a)))
           (vl-string->list s)
Can help me ? or
Will you share what you've written to do that? Thanks very much!
I don't know why garbled(unreadable codes) , ??? :cry::cry:
