Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > AutoCAD > AutoLISP, VBA, the CUI & Customisation
Closed Thread
Thread Tools
Old 18th Sep 2006, 10:46 pm   #1
CADTutor
Administrator
CADTutor's Avatar
Using: AutoCAD 2010
FAQ Article Code posting guidelines
When you are posting AutoLISP or VBA code in these forums, there are some simple guidellines you should observe in order to make life easier for you and for others.
Always place routines or code snippets between code tags. This makes them easier to read within posts by making them distinct from other text. It helps those who may want to copy and paste the code. It also helps to save space because code blocks get a scroll bar beyond a certain number of lines.
To place your code between code tags, type the code first, click and drag to highlight the code and then click the code button on the editor toolbar. That's the one with the "#" on it*. When you submit the post, the code will be displayed as shown below.
Please ensure that you have the right to publish code on a public forum. In most cases, the code you are publishing will be your own and it will be assumed that if no attribution is given, you are the author. However, if you are not the author, you must make this clear and where possible, give credit to the author. Any routines published here must have their header intact, including any title, instructions, author contact details, date and copyright information. If at all possible, please make sure that you have the the authors permission to publish their work.
The code shown above has been published with its header intact. It is important to include this information even if the author intended to make the code freely available.
* If you do not see a "#" button on your toolbar, see this article.
Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
CADTutor is offline
Closed Thread
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Please Read This Before Posting CADTutor AutoCAD General 18 13th Feb 2008 10:10 pm
Inventor FAQ Please read BEFORE POSTING Mr T Autodesk Inventor 0 3rd Oct 2005 07:40 pm
Guidelines on publication of AutoLISP routines CADTutor News, Announcements & FAQ 0 1st Aug 2005 10:39 am
Email Error on Posting CADTutor News, Announcements & FAQ 3 29th Dec 2004 05:10 pm
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
