guitarguy1685 Posted May 29, 2015 Share Posted May 29, 2015 I have a block that when inserted from the Toolpalette it is changing the units. Let me explain. 1st I created a dynamic block in metric (mm). INSUNITS are set to 4. Next I created a new drawing whos units are set to (in) INSUNITS = 1 I use the INSERT command to insert the block. At the INSERT dialog box I notice that the Block Unit is set to "Millimeters" (which is correct) and Factor set to 0.0394 (which is correct for converting mm to in). I insert the block and it works as I expect. When i click on the block properties is says the Scale of the block is 1. I figure ACAD is doing some scaling behind the scenes here. So now I create another new drawing. This time I use the Toolpalette to insert the same block. When I click the icon in the palette the block is HUGE and I can't see what it looks like unless I zoom out. After I select the insertion point ant rotation the block is scaled down....weird So then I click on the properties of the block and it says the Scale is 0.0394 not 1 like in the 1st drawing. I go to the block editor of to check units of the block and I notice it was changed to "UNITLESS". WTF???? Why did Toolpalette change my blocks units from (mm) to unitless? Any ideas? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 30, 2015 Share Posted May 30, 2015 If the block unit is mms , why are you setting the insert units to centimeters ? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 30, 2015 Share Posted May 30, 2015 Rereading your post, I am guessing that you have created your new drawing with insert units sets to on a metric template, probably the same one on which you created your dynamic block. I suggest that you open the original drawing of the dynamic block, and run the -dwgunits command on it, as more than likely you will come to understand the problem by studying the commandline prompts. If you post the dynamic block, I am sure somebody will be able to figure it out for you. If you do it soon, I will be happy take a look. Quote Link to comment Share on other sites More sharing options...
guitarguy1685 Posted June 1, 2015 Author Share Posted June 1, 2015 INSUNITS 4 is mm for me. I've attached the block. take a look and maybe you'll see something I missed. Thanks. RB22-16-DYN.dwg Quote Link to comment Share on other sites More sharing options...
