structo Posted October 21, 2016 Share Posted October 21, 2016 Hi All, How to convert my drawings from X-Y to X-Z by Lisp? please help. Thankyou. Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted October 21, 2016 Share Posted October 21, 2016 Use the _3DROTATE command. Or start a new dwg, flip the UCS and insert. Quote Link to comment Share on other sites More sharing options...
structo Posted October 21, 2016 Author Share Posted October 21, 2016 ROY, thanks for reply. any lisp routine for quick operation (XY plane to XZ plane)? i have tried _3DROTATE. but not getting good results. Thanks. Quote Link to comment Share on other sites More sharing options...
lrm Posted October 21, 2016 Share Posted October 21, 2016 I prefer rotate3d to 3drotate. Here are the prompts and response to go from XY to XZ. Command: ROTATE3D Current positive angle: ANGDIR=counterclockwise ANGBASE=0 Select objects: Specify opposite corner: 5 found Select objects: Specify first point on axis or define axis by [Object/Last/View/Xaxis/Yaxis/Zaxis/2points]: x Specify a point on the X axis : Specify rotation angle or [Reference]: 90 ~Lee Quote Link to comment Share on other sites More sharing options...
rkent Posted October 21, 2016 Share Posted October 21, 2016 I rotate the UCS and then just use Rotate command. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 21, 2016 Share Posted October 21, 2016 I have never had a problem with rotate3d, one suggestion Specify a point on the X axis : pick the lower left point of your object Quote Link to comment Share on other sites More sharing options...
