danglar Posted October 25, 2016 Posted October 25, 2016 ... in some cases you need to array "dirty maked" blocks.. I mean you need to combine blocks array with change insertion point of the block and even to rotate it around base point. I "dirty" combined these subroutines into one (see attached lisp) and now I need some improvement: When first subroutine ended to work the second one must to use previous selection set and when second one ended the third one will use previous selection set .. Is it possible to do? Block Array - BR.lsp Quote
BIGAL Posted October 26, 2016 Posted October 26, 2016 Did not look to hard but the problem is probably in your defuns ( ent / newent) you want newent in next function so remove from the localised defun definition. (ent ) Quote
danglar Posted October 26, 2016 Author Posted October 26, 2016 Hi Bigal! Thanks for quick answer Can you explain how to do it by example? Quote
