Alcapone001 Posted January 19, 2017 Posted January 19, 2017 Hello everyone. I need a lisp to generate x y z values for contours from civil 3d to excel, into separate columns. Any ideas Thank you. Quote
gS7 Posted January 19, 2017 Posted January 19, 2017 did you tried import/export tool in c3d Sent from my SM-E700H using Tapatalk Quote
BIGAL Posted January 20, 2017 Posted January 20, 2017 You can convert CIV3D contours to plines and then could export out all the co-ordinates, the output file could be horrendous. You could export out at a spacing interval. I think you need to explain more why do you need the contour co-ords ? Quote
Alcapone001 Posted January 20, 2017 Author Posted January 20, 2017 I am analysing a pipe network using some other software, which currently has no way of importing the contours in their current form. Hence the reason i need the contour x y z coordinates as text, preferably in excel Quote
Alcapone001 Posted January 20, 2017 Author Posted January 20, 2017 Yes I have. No option for exporting contour values to text Quote
gS7 Posted January 20, 2017 Posted January 20, 2017 (edited) May be this one helps you (only work for 3DPOLYLINES) (defun c:3dexport (/ *error* file sset pnt ssnm i vn omit ) (defun *error* (msg) (if file (close file)) (cond ((not msg)) ((member msg '("Function cancelled" "quit / exit abort"))) ((princ (strcat "\nError:" msg))) ) (princ) ) (if (setq sset (ssget "_:L" '((0 . "POLYLINE")))) (progn (if (setq file (open [color="red"](getfiled "File to Save" "C:\\" "csv" 1)[/color] "w")) (progn (write-line (strcat "Point No." "," "X" "," "Y" "," "Z") File) (setq pnt 1) (_Layer "Point_Text" 2) (repeat (setq i(sslength sset )) (setq ssnm(ssname sset (setq i(1- i)))) (setq vn (entnext ssnm)) (while (/= "SEQEND" (cdr (assoc 0 (entget vn)))) (setq pts(cdr (assoc 10 (entget vn)))) (_MakeText pts (rtos pnt 2 0) (getvar 'DIMSCALE) (Getvar 'TEXTSTYLE) "Point_Text") (setq omit (strcat (rtos pnt 2 0) ","(rtos (car pts) 2 4) "," (rtos (cadr pts) 2 4) "," (rtos (caddr pts) 2 4))) (write-line omit file) (setq vn(entnext vn)) (setq pnt(1+ pnt)) ) ) (close file) ) ) ) (*error* "Nothing Seleted:") ) (*error* nil) (princ) ) (defun _MakeTExt(point name ht style layer) (entmake (list (cons 0 "TEXT") (cons 10 Point) (cons 1 name) (cons 40 ht) (cons 7 style) (cons 8 layer) ) ) ) (defun _layer(name col) (if (not (Tblsearch "LAYER" name)) (command "_LAYER" "n" name "c" col name "") (command "_LAYER" "t" name "ON" name "c" col name "") ) ) Edited January 20, 2017 by gS7 Quote
Alcapone001 Posted January 20, 2017 Author Posted January 20, 2017 My contours are all 3d polylines. when i use the lisp it shows 372 objects found. but nothing happens next Quote
gS7 Posted January 20, 2017 Posted January 20, 2017 (open (strcat "D:\\Contour_Points" ".csv") "w")) Please Type Drive to save file Quote
Alcapone001 Posted January 20, 2017 Author Posted January 20, 2017 How do i set it up to save to the desktop Quote
gS7 Posted January 20, 2017 Posted January 20, 2017 Code updated in # 6 Now you sav save file anywhere Quote
Alcapone001 Posted January 21, 2017 Author Posted January 21, 2017 Though it is not picking all the 3d contour polylines, i dont know why.. Quote
gS7 Posted January 21, 2017 Posted January 21, 2017 Please attach sample Drawing file which is not selecting contours lines Quote
